Thread: rattling noise 2004 pontiac grand prix
Results 1 to 13 of 13
  1. #1 rattling noise 2004 pontiac grand prix
    Sep 2012
    california
    Hello, my 2004 pontiac grand prix has started making a rattling noise lately. This noise can only be heard when I accelerate and also when I make a left then it makes a loud rattling noise. When I'm stopped it doesn't make the noise. I notice that when I go faster it seems to go away until I drive at lower speeds. If I put it in park and push the gas the noise is gone. It seems like the engine is getting hotter then normal and I can smell oil. Any ideas on what can cause this?
  2. #2 Re: rattling noise 2004 pontiac grand prix
    Sep 2012
    california
    And the noise is definitely coming from drivers side under the hood I believe
  3. #3 Re: rattling noise 2004 pontiac grand prix
    St. Louis
    Try taking the belt off and spinning the pulleys by hand and see if any of them sound bad, and wiggle them too. If any of them seem loose then it could be that. Barring that, could be a wheel bearing or something suspension related, but that wouldn't cause it to run hot. And by hot, where exactly on the gauge does it get to?
  4. #4 Re: rattling noise 2004 pontiac grand prix
    Sep 2012
    california
    The gauge goes about a little over half of the way up to where it would be over heating. But never over heats. It has before and my car would shut off. Found out it was the water pump and replaced it. The mechanic said the thermostat was fine. When I went for a smog, it passed, but the guy their told my that it is leaking oil out if the gasket and that it would cost upwards of $400 to fix. I have seen a little oil on the engine and I wash it off. Could a leaky gasket cause this? I check the oil regularly and its fine. One other thing I could add is I noticed under the radiator cap it has some rusty mud looking build up. And the coolant looked like it also had some of that rust in it. I also heard oil on spark plugs could cause this but not sure.
  5. #5 Re: rattling noise 2004 pontiac grand prix
    Sep 2012
    california
    And I hear the noise when I make a left turn,car can be hot or cold, but not so Much when I make a right. But definitely if I drive on the freeway and exit the car will make that noise every time I push the gas and gets louder when I begin to accelerate but goes away when i reach higher speeds. I have put the car in neutral and park and pushed the gas and nothing. It's only when in drive. Also the past few days, when I stop for a sign or light and go, it has jerked on me like when I pushed the gas to go. That has happened to me 2-3 in the past week.
  6. #6 Re: rattling noise 2004 pontiac grand prix
    St. Louis
    Muddy looking coolant could be a sign of leaking LIM gaskets. Since you have an 04 it probably still has the black plastic gaskets in it. Look between the LIM where it meets the heads and if you see black, then there's your answer. The new ones are aluminum. Where exactly is it leaking oil from? Pics could help if all else fails.
  7. #7 Re: rattling noise 2004 pontiac grand prix
    Sep 2012
    california
    Yes they are black. And the oil seems to be puddling up just underneath it .
  8. #8 Re: rattling noise 2004 pontiac grand prix
    Sep 2012
    california
    Also I noticed the little container where the reserve collant goes doesn't add to the radiator when its low. It stays at the fill line but I have taker the radiator cap off and poured coolant manually because it was low. So for some reason its not sucking it from the reserve tank.
  9. #9 Re: rattling noise 2004 pontiac grand prix
    Sep 2012
    california
    But it might be the upper manifold right where I add oil, that's where the oil is and the gasket looks like black plastic.
  10. #10 Re: rattling noise 2004 pontiac grand prix
    Sep 2012
    california
    The lower looks aluminum
  11. #11 Re: rattling noise 2004 pontiac grand prix
    your rambling all over the place lol
    the coolant tank, make sure the hose is clear, not clogged, you may need a new rad cap.
    oil leaks, could be the valve covers, also could be the lim bolts leaking coolant and oil from the bolts.
    not a clue what your noise is., none of this^^^^is making noise.
    if you can, please post up a vid of said noise.
  12. #12 Re: rattling noise 2004 pontiac grand prix
    Sep 2012
    california
    Sorry about that. I will try and post a video or pictures ASAP. Just that sound is really annoying and idk if its gonna cost an ARM n a leg to fix
  13. #13 Re: rattling noise 2004 pontiac grand prix
    Nov 2021
    Reading, PA
    You're probably hearing a failing torque converter. I have the same issue. It's louder in left turns and barely there in rights. From what I've gathered the factory converter is kinda **** and rattles right before it dies. Check your trans fluid and talk to an experienced tech. Your trans is most likely on it's last legs.
  1. What is the best way to sell my 2004 Pontiac Grand Prix?
    By pgpaz2004 in forum Introductions/Noob Questions
    Last Post: 03-18-2012, 10:00 PM
  2. 1996 Pontiac Grand Prix SE noise
    By moospis in forum General Tech Discussion
    Last Post: 08-20-2010, 04:51 AM
  3. 2004 Pontiac Grand Prix GT1 Issue
    By rawr in forum General Tech Discussion
    Last Post: 11-28-2009, 02:15 AM
  4. 2004 Pontiac Grand Prix
    By davma1 in forum General Tech Discussion
    Last Post: 08-31-2009, 08:36 AM
