Thread: Vibration.
Results 1 to 20 of 20
  1. #1 Re: Vibration.
    GT Level Member mguzzo's Avatar
    Buffalo NY
    RE; vibration - if you are significantly lowered it messes up the CV angle. do you have shortened dogbones, they move the engine forward to relieve some of the angle. other option is cradle spacers.
    for your trans issue read this TCC rpm oscillation and see if it describes your symptoms
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  2. #2 Re: Vibration.
    Oct 2019
    Ridgecrest ca
    Quote Originally Posted by mguzzo View Post
    I’ll read it on my lunch, the vibration I’m pretty sure is that, I’m going back up with it, not a fan of big drops. Cv’s will be replaced as well as I have no clue how long it’s been lowered.
  3. #3 Re: Vibration.
    Oct 2019
    Ridgecrest ca
    The vibration is more than likely the cv’s. Just need to get to fixing it.
    On the tcc issue, if I lightly touch the brake pedal while accelerating, it will exit lockup and the issue goes away. Hopefully it’s not rebuild time. I’ll try a trans filter and fluid change first, see if anything improves. As of right now time just isn’t on my side.
  1. Vibration?
    By cavell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-18-2013, 03:31 PM
  2. Vibration at 70 mph
    By KoldAsIce in forum Brakes/Suspension/Chassis
    Last Post: 06-25-2013, 04:22 PM
  3. bad vibration???
    By M.$tErNeR in forum Brakes/Suspension/Chassis
    Last Post: 05-20-2010, 03:45 AM
  4. Vibration
    By Klutch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-26-2009, 02:52 PM
  5. Odd Vibration
    By VGPGT in forum General Tech Discussion
    Last Post: 04-15-2009, 04:18 PM
