Thread: Bizarre Electrical Issue
Results 1 to 3 of 3
  1. #1 Bizarre Electrical Issue
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Twice now, when I've taken the key out, the entire car has shut down. Then when I get out to check the battery. it comes back to life, having erased the settings on the DIC and the stereo. It works fine after that, until the next time.
    Any ideas?
  2. #2 Re: Bizarre Electrical Issue
    St. Louis
    Maybe ignition switch? If the battery and cables are all good.
  3. #3 Re: Bizarre Electrical Issue
    might be the small grounds on the trans bell housing, where the main neg cable bolts to as well. the wires start to break off the eyelet. when this happens some people complain the dash lights cut off and on over bumps.
  1. Tuning issue or electrical issue?
    By blueanchorgtp in forum PCM Tuning
    Last Post: 12-25-2017, 05:35 AM
  2. Bizarre issue with key fob (Tried ALL obvious fixes)
    By komrad36 in forum General Tech Discussion
    Last Post: 08-08-2013, 10:34 PM
  3. 99 GTP Electrical issue
    By LS1z2800 in forum General Tech Discussion
    Last Post: 05-06-2011, 07:01 PM
  4. VERY ODD electrical? issue
    By Pittman06 in forum General Tech Discussion
    Last Post: 01-18-2010, 07:30 PM
  5. electrical issue
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 12-10-2009, 10:49 PM
