Thread: Air Conditioning blows through vents and then to floor.
Results 1 to 4 of 4
  1. #1 Air Conditioning blows through vents and then to floor.
    Apr 2014
    Surprise, Az
    My air conditioning blows very cold. It blows hard through the vents and out of nowhere and for no reason it will blend to the floor. then sometimes it comes back to the vents all on its own. i could be cruising on the freeway with CC on and it will change whenever it wants. Is it an actuator or a vacuum issue?
    I searched everything air conditioning on here and nothing looked to be the same issue.
  2. #2 Re: Air Conditioning blows through vents and then to floor.
    St. Louis
    Sounds like a vacuum leak somewhere. I had a car doing this and it was the actual control head for the ac/heat.
  3. #3 Re: Air Conditioning blows through vents and then to floor.
    Feb 2018
    Las Vegas
    I had the same issue on my 98 GTP and it was the Climate Control Vacuum Valve. Located under the glove box, it's an assembly of relays. Rockauto has them.
  4. #4 Re: Air Conditioning blows through vents and then to floor.
    Jul 2010
    Coquitlam,BC,Canada
    I second the vacuum leak. I had one a few months back which caused weak air in all vent locations, no matter what I did.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Heater blows cold when set to hot and blows hot when set to cold??????
    By Markgp in forum General Grand Prix Discussion
    Last Post: 10-29-2013, 07:38 PM
  2. Replies: 1
    Last Post: 03-08-2012, 01:07 PM
  3. 98 gtp w/ DCC will blow on defrost or vents but not floor-please help
    By Liquifire in forum General Tech Discussion
    Last Post: 08-03-2011, 06:07 PM
  4. Front Dash & Floor Air Vents Blocked!
    By marwan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2010, 11:00 PM
  5. air conditioning
    By handirifle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2009, 04:00 AM
