Thread: 99 GTP Orifice tube
Results 1 to 5 of 5
  1. #1 99 GTP Orifice tube
    May 2018
    Knoxville TN
    Just finished putting in a new compressor, accumulator, and orifice tube. The orifice tube was a major p.i.t.a.! If anyone is contemplating this job, it was a *****, but doable. I have a 99 GTP, I'm the original owner. Im on compressor number three, the factory original lasted about 16 years, then I've run two junkyard compressors, getting like a year or so service out of each. When the last one died I bit the bullet and went new. Anyway if anyone is contemplating doing this, I had to move the ABS, master cylinder and cruise control module out of the way, but I did not have to disconnect any brake lines or move the brake booster. What worked for me tool-wise was a 1 1/16 crowfoot, along with a stubby crescent wrench. The crowfoot was slightly large, and I have read that the nut is supposed to be 26mm, but no one here in TN had that wrench size so I went with the 1 1/16. Also see the pic below, I see alot of guys opt not to change the orifice tube because its hard, but after 20 years mine was really bed.
  2. #2 Re: 99 GTP Orifice tube
    St. Louis
    Did that job on my 00 GT. NOT something I ever want to do again. And the tube looked exactly like yours. Just baked on junk. Works much better now.
  3. #3 Re: 99 GTP Orifice tube
    May 2018
    Knoxville TN
    It's holding vac overnight so far. Going to charge it up later this afternoon. When you did your car, did you notice the a/c being any colder?
  4. #4 Re: 99 GTP Orifice tube
    St. Louis
    Yes, the vent temps did drop some.
  5. #5 Re: 99 GTP Orifice tube
    May 2018
    Knoxville TN
    OK Thanks. Charged mine up yesterday, it's been nice and cold, no leaks so far.
  1. orifice tube
    By rockquarryman in forum General Tech Discussion
    Last Post: 07-30-2014, 01:37 PM
  2. Changed my Orifice Tube. It Sucked
    By Lonestargp in forum General Tech Discussion
    Last Post: 04-16-2010, 08:35 AM
  3. Where the heck does this orifice tube go!? 1998 GTP
    By copgtp in forum General Tech Discussion
    Last Post: 04-13-2010, 04:36 PM
  4. Orifice Tube Location?
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2009, 12:58 AM
  5. Orifice Tube
    By Damojo2003 in forum General Tech Discussion
    Last Post: 04-23-2009, 05:14 AM
