Thread: Driver side wiper not moving / floping around
Results 1 to 7 of 7
  1. #1 Driver side wiper not moving / floping around
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    it snowed this past weekend and i turned on the wipers to clear a light accumulation off the windshield, maybe half an inch or less. The passenger side wiper when right along but the driver side didnt move.
    After clearing the windshield the driver side moved, but stopped when it encountered any resistance, and started getting caught in the path of the passenger side.
    The Wiper motor seems to be fine.
    Any suggestions? My thoughts are to see if the spline is stripped, and if its not, i figure the wiper transmission failed.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: Driver side wiper not moving / floping around
    theres a cap at th ebase of the wiper arm, remove it and tighten the nut you see there under the cap. do this wiper in off position and push the wiper down, then make it tight
  3. #3 Re: Driver side wiper not moving / floping around
    Jul 2010
    Coquitlam,BC,Canada
    What Scotty said. The wiper linkage connects the two arms, so if one isn't working, the problem has to be in the spline's.
    Here is a pic of the drivers side nut, cuz I'm a picture nut. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Driver side wiper not moving / floping around
    SE Level Member sn95gt50's Avatar
    Jul 2008
    2008 Grand Prix base model
    Similar issue, on daughters car, is the arm splined to the spindle, or does the pressure from the nut pushing against the arm keep the shaft from spinning on the shaft? I removed the nut and the arm would not come off, didn't try that hard and ddon't have a puller for it. I positioned the arm in the parked position and then tightened the nut. Checked torque at 20 ft-lbs and it was at least that tight. Tried wipers and they now appear to work fine.
    Is that all there is to it, or do I need to replace the arm if splines are sheared off.
    Thanks,
    John
  5. #5 Re: Driver side wiper not moving / floping around
    St. Louis
    Nope, if it works now then it's tight enough. My drivers side used to come loose so often that I carry around a wrench just for that use. Original arms on 00 GP and still have not stripped it out. Yes there are small splines on it but when it loosens up the arm walks up the mount and then just flops around if it gets a bite.
  6. #6 Re: Driver side wiper not moving / floping around
    i just had to tighten up the arm on my tahoe. regals both came free at one point. also last year had to do the work trucks arm. its part of owing a gm car it seems lol
  7. #7 Re: Driver side wiper not moving / floping around
    Jul 2008
    Thanks for the responses, they appears to be working now.
  1. windshield wiper vacuum line driver side connection
    By SgtMarshal in forum General Tech Discussion
    Last Post: 02-12-2016, 09:18 PM
  2. Driver side windshield wiper swings out past the edge of windshield
    By jcvv in forum General Grand Prix Discussion
    Last Post: 04-13-2014, 02:51 PM
  3. Driver's Side Windshield Wiper Stopped Working.
    By Chaotic94 in forum General Tech Discussion
    Last Post: 02-27-2011, 05:29 PM
  4. Driver side wiper arm slips down to the side mirror
    By kappian in forum General Tech Discussion
    Last Post: 04-05-2010, 08:43 PM
  5. Wiper arm not moving?
    By Sheepdog in forum General Tech Discussion
    Last Post: 12-17-2009, 10:52 AM
