Thread: 1998 GTP Coupe Multiple Issues! Please Help!
Results 1 to 10 of 10
  1. #1 1998 GTP Coupe Multiple Issues! Please Help!
    Mar 2019
    Garden CIty
    Hello all!
    New member here looking for a bit of guidance. I recently won a 1998 Pontiac GTP Coupe at an auction and it is SUPER Clean. It has 76K original miles on it. The battery was DEAD (stamped 4-17-2006). I have installed a new battery and now have power and the car does crank.
    I cannot get it to shift out of park however. I got it loaded/unloaded on a trailer by unhooking the shifter cable under the hood and manually shifting it into nuetral by hand. (It shifted effortlessly by hand) I do have brake lights that work when contacting the pedal, however the shift lock release button does not allow me to shift out of park. I have opened the entire center console and everthing looks as I would expect. I am kind of stuck there.
    A little further information, the car has approx 3/4 of a tank of fuel and it smells like good fuel at the gas cap as well as the schrader valve on the fuel rail. I do have fuel pressure on the fuel rails as well. I have hit the throttle body with a quick squirt of starting fluid and the car fires up and dies within a couple of seconds. I am wondering if I might have a tank of bad/old fuel or if it could be tied to the shift issues.
    I have looked through the owners manual and checked any fuses that appear to have anything to do with the shifter or shift lock release and all appear to be good. I am at a loss on what to do or check next.
    This was a dream car of mine when in high school and I have a SUPER CLEAN example of one now with LOW miles! I am dieing to get this baby on the road again! Any and all insight is GREATLY APPRECIATED!!! Thank you all so much in advance!!!
  2. #2 Re: 1998 GTP Coupe Multiple Issues! Please Help!
    GTP Level Member
    Oct 2014
    Put a fuel pressure gauge on it. 1 psi less than min and they wont start. Something like 40-50 psi.
    If the fuel pressure regulator is bad you may get it to start by stepping on the gas a bit while cranking.
  3. #3 Re: 1998 GTP Coupe Multiple Issues! Please Help!
    Apr 2014
    commerce twp,mi
    id encourage you to not chance the fuel- drop the tank ,empty,and see how it looks inside. it would be wise to change the fuel filter,too.
    did you happen to be stepping on the brake pedal when trying to shift?
  4. #4 Re: 1998 GTP Coupe Multiple Issues! Please Help!
    Mar 2019
    Garden CIty
    Quote Originally Posted by markpa View Post
    Im about to go to Harbor Freight and grab a kit to test the fuel pressure. Thanks for in input Sr!
  5. #5 Re: 1998 GTP Coupe Multiple Issues! Please Help!
    Mar 2019
    Garden CIty
    Quote Originally Posted by tomsteve View Post
    I have a fuel filter to chage too. Going to check pressure first. Then probably will drain all fuel as noted and check the tank.
  6. #6 Re: 1998 GTP Coupe Multiple Issues! Please Help!
    Don't drop the tank first.
    Open the trunk access panel for the fuel pump and yank it out there, then look inside the tank if you need too.
    If you don't hear the pump prime and cycle for 2 seconds, the pump is likely dead from sitting for so long. You can smack the bottom of the tank with a mallet a bunch to try and make it come back to life but that is only a short term fix.
  7. #7 Re: 1998 GTP Coupe Multiple Issues! Please Help!
    Mar 2019
    Garden CIty
    Just an update. The fuel pump is out of it. I have no fuel pressure and I cannot hear it prime. (Took the cover off of it in the trunk) I also checked the harness with a voltmeter and when you turn the key on I get 11.7 volts at the harness. So I know that the system is working to that point. Autozone wants $229 for one but i have found several online for the 60 dollar range with good reviews. I am going to order on off the net and install once it arrives. I also bought a hand pump. I think I will drain as much fuel out as possible and into 5 gallon buckets. Then replace with good fuel and some injector cleaner/sea foam.
    Now my issue for the time being falls back to the gear shifter. I am thinking the button you depress is unhooked or malfunctioning. Going to dive into that issue while I wait for a fuel pump to arrive. If anyone has any ideas or suggestions I sure would appreciate them. Again thanks all!
  8. #8 Re: 1998 GTP Coupe Multiple Issues! Please Help!
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    I'm pretty sure you need to step on the brake pedal to shift from park. I didn't see that you did that.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  9. #9 Re: 1998 GTP Coupe Multiple Issues! Please Help!
    Mar 2019
    Garden CIty
    I have my shifting issue resolved. The shift knob was raised off of the lever. The U clip was bent and allowed the lever to go higher than it needed to be to properly operate. I pulled the U clip and used channel locks to bend it back properly. I reinstalled it and now we shift properly.
    I have a couple small issues left (window wont roll up) possible bad motor. Going to get my test light out and investigate. Other than that I am just waiting on my new fuel pump.
    Again Thanks everyone!
  10. #10 Re: 1998 GTP Coupe Multiple Issues! Please Help!
    Jul 2017
    macomb mi
    could be a bad window switch my moms friend her passenger window wouldn't go up no matter if you use the driver switch or passenger switch so i assumed it was the motor but then i used a trick i learned from some of the test guys at my work and i took a dewalt battery and connected two wires from the battery to the pins on the motor and sure enough went up and down fine swapped out the switch took me 20 min she told me i saved her from paying a shop $450 so she threw me like $60 i was more than happy haha
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  1. Multiple Issues... maybe
    By DaFrost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2017, 03:05 PM
  2. Multiple Issues
    By aprose in forum General Tech Discussion
    Last Post: 04-23-2012, 01:04 PM
  3. Multiple car issues.
    By suzie in forum General Tech Discussion
    Last Post: 02-25-2011, 07:00 PM
  4. 97 GTP multiple issues
    By Ainrev in forum General Tech Discussion
    Last Post: 02-04-2011, 04:06 PM
  5. multiple issues, help?
    By Brammer in forum General Tech Discussion
    Last Post: 10-04-2010, 03:37 PM
