Thread: Fuel Gauge
Results 1 to 4 of 4
  1. #1 Fuel Gauge
    Oct 2018
    OH
    The fuel gauge on my 2001 Grand Prix GT slowly moves around. If it has 1/4 track, it may read anywhere from 1/4 to full. If actually full, it stays on full. I'm thinking it needs a new sending unit in the tank. No? I assume I'll need to drop the tank to access it?
  2. #2 Re: Fuel Gauge
    St. Louis
    Yes, you need a new sending unit. 01 may or may not have an access panel as they were phased out in later years. Pull up the carpet in the trunk near the back seat and see if you have an access panel bolted to the floor. If you do, then just undo the bolts, remove the panel and walah- there's the top of your fuel tank along with the pump.
    If not, then some have cut an access hole for this reason. Or you can go through the hassle of dropping the tank.
  3. #3 Re: Fuel Gauge
    Oct 2018
    TX
    Sending unit for sure. When the sending unit went out on my 2002 Pontiac GTP I upgraded the pump with the E85 Aem zzp sells. Also the in trunk fuel pump access cover wasn't phased out until 2004. Unless you wanna count miles get it repaired, it's quite easy. Let me know how it goes.
  4. #4 Re: Fuel Gauge
    Jul 2010
    Coquitlam,BC,Canada
    Could be the fuel level sensor.
    Fuel_Level_Sensor
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. SC Modular Pulley - Gauge Pod - Air/Fuel Gauge
    By 02GTPJeff in forum For Sale - Parts
    Last Post: 01-14-2016, 07:08 AM
  2. Replies: 7
    Last Post: 07-15-2015, 03:41 PM
  3. fuel gauge or......
    By dpcp66 in forum General Tech Discussion
    Last Post: 07-12-2015, 01:59 AM
  4. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
