Thread: Steering resistance
Results 1 to 3 of 3
  1. #1 Steering resistance
    MD
    '99 Grand Prix 3.8
    I had a problem with a vibrating steering wheel when braking but that is now fixed (warped discs). Now there is no vibration when driving straight or braking.
    Now a new problem. When I am driving on a straight road and turn the steering ever so slightly on the curves (40-50 mph), I feel a very slight resistance in the steering wheel. This is not a strong pull, or a noise of any kind. The resistance is not steady either, it feels like it pulsates, almost as if someone is grabbing the releasing the steering column very fast as I try to turn.
    I am able to turn and drive without a problem, but this is a bit bothersome.
    Have read that possible causes are low PS fluid, leak in the R&P or needing a whole new R&P. Any ideas or things to check?
    If it the R&P, is this a DIY job? I have a good jack and stands, but no access to a lift. I have done front ends, tie rods, bearings, brakes, etc.
    Thanks
  2. #2 Re: Steering resistance
    St. Louis
    You can DIY the rack. I did it on my 00 GT.
  3. #3 Re: Steering resistance
    Oct 2011
    Toledo, OH
    My 05 has been doing that for 5+ years. I always thought it had something to do with the Magnasteer. There is a YouTube video showing how to replace the rack in 30 minutes.
  1. Loose steering after replacing intermediate steering shaft on 06 GP GT
    By Tross901 in forum Other 3800 Powered Cars
    Last Post: 06-03-2015, 10:56 AM
  2. [?] steering column plastic / intermediate steering shaft question
    By localhost127 in forum General Tech Discussion
    Last Post: 06-10-2013, 08:33 PM
  3. fuel injector resistance
    By Viprklr in forum 5.3L V8 (LS4)
    Last Post: 06-17-2012, 11:48 AM
  4. What resistance should the coil packs have?
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2011, 11:33 AM
  5. a little resistance with steering wheel
    By johnnyj773 in forum General Tech Discussion
    Last Post: 05-10-2008, 02:28 PM
