Thread: Ease of installation of a PLOG
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 70
  1. #1 Ease of installation of a PLOG
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    So I'm getting a plog soon and I want to know how easy it is to install. I believe there are 8 total bolts. Whats the best way to go about doing the install? I'll start spraying the bolts with pb blaster a couple day's before I receive the plog to help the bolts come off easier. I also bought the manifold gasket from zzp so I will RTV both sides of that. Thanks for the info.
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Ease of installation of a PLOG
    antioch ill
    no need for rtv. and it can be a pita to get the nuts off.
  3. #3 Re: Ease of installation of a PLOG
    Apr 2013
    Milwaukee
    Damn, not what I wanted to hear
  4. #4 Re: Ease of installation of a PLOG
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    I broke a stud off in my head when installing headers wasn't fun to get out either
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: Ease of installation of a PLOG
    Once you start taking your headers off every six months, the bolts will never be seized.
  6. #6 Re: Ease of installation of a PLOG
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    You're probably better off to start spraying **** on those bolts earlier than a few days before. Either way, it's going to sssuuucckk.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  7. #7 Re: Ease of installation of a PLOG
    Apr 2013
    Milwaukee
    Ughhh I might just take it in to a tuner shop to get done. They will have access to torches and air gun's which will most likely help ton's.
  8. #8 Re: Ease of installation of a PLOG
    Can't buy a MAP/pro bottle and torch?
    Air gun won't help either.
    It's all 1/4" ratchet and 13 MM wrench.
  9. #9 Ease of installation of a PLOG
    And expect to get charged out the butt for something like that too...and wasn't the whole reason that you didn't go headers was because money was low so taking it to a shop will defeat the purpose.
    Pb blaster + breaker bar and or buy something to heat it up a bit= mission accomplished.
    04 Comp G.
  10. #10 Re: Ease of installation of a PLOG
    Apr 2013
    Milwaukee
    Alright I guess I could try. Just don't want to bust bolts and make it more of a pita then it already will be. I'll probably be getting it by the end of the week so I'll start pb'ing it tomorrow and buy a decent torch.
    Sent from my PantechP8010 using Tapatalk
  11. #11 Re: Ease of installation of a PLOG
    Don't catch your car on fire either...have something to put it out just in case.
    04 Comp G.
  12. #12 Re: Ease of installation of a PLOG
    I've never had a problem getting any of those bolts out. Should be an easy hour or less job.
  13. #13 Re: Ease of installation of a PLOG
    Nov 2011
    NY
    But really... PB blaster only goes so far... If you want to loosen bolts, make what NASA uses... 50/50 mix of acetone and ATF in a spray bottle is all you need, especially if you can let it sit a while. Will loosen almost anything! Breaker bar helps if stuck
    Personally, Plog is half a set of headers and why not just go all the way and get headers! Just sayin...
  14. #14 Re: Ease of installation of a PLOG
    Antioch, IL
    My bolts came out with a 3/8 ratchet......... no breaker
    2009 Challenger SRT8
    Expert at being gay.
  15. #15 Re: Ease of installation of a PLOG
    Apr 2013
    Milwaukee
    Dang wouldn't that mixture eat up the bolts? Lol I should try that though for kicks. I would have got headers, but I have a dp already and don't feel like taking it off to sell. Possibly in the future when I'm good on money.
  16. #16 Re: Ease of installation of a PLOG
    Apr 2013
    Milwaukee
    Just to be sure, I shouldn't use rtv right? Or it's not needed?
  17. #17 Re: Ease of installation of a PLOG
    Dec 2010
    DMV
    Not needed
    Sent from my HTC One using Tapatalk
  18. #18 Re: Ease of installation of a PLOG
    Apr 2013
    Milwaukee
    K
  19. #19 Re: Ease of installation of a PLOG
    Not sure of the prior experience of the guys that have already commented, except for DSmuts.
    Here's the super simple Bill method:
    Remove airbox tube out.
    Loosen the crossover bolts 1/2 turn each until loose. This backs them off equally and gives you a 95% chance of pulling them w/o any issues.
    Remove both dog bones
    Remove 13mm nut for oil dipstick tube, wiggle and remove tube.
    Remove the bolts holding the middle of the manifold.
    Remove the two nuts holding the ends of the manifold
    Take manifold off
    Remove factory gasket
    Wipe factory gasket clean with a nice rag and brake cleaner
    Wipe head surface
    Reinstall factory MLS gasket on studs
    Wipe surface of PLOG that will mate to gasket with brake cleaner
    Look down and note where dipstick tube needs to go when installing, this is a great chance to see the location.
    Install plog and all the bolts that hold it to the head.
    Reinstall dipstick (sometimes having someone underneath and using the dipstick inserted into the tube helps guide it.
    Reinstall dipstick retaining nut
    Bolt crossover to plog
    Reinstall air tube.
    If you think you need heat to do the job. Skip the torch, skip the shop, skip all the silly steps mentioned. Before you start the job, start the engine and let it get some temperature in it. Shut it off and loosen the bolts you are worried about, magical isn't it?
    I've had two bolts snap in heads out of a few thousand, it's rare if you hold the ratchet/socket straight and don't turn it the wrong way.
  20. #20 Re: Ease of installation of a PLOG
    Texas
    Holy crap. You guys must have had some serious problems with yours. Lol
    Spray PB blaster like you mentioned and then go to town. I would suggest that when you go to reinstall connect it at the crossover first then install the other bolts.
    85 Corvette
    01 TA
    03 Z06
  1. A-Pillar Gauge Pod and Gauges - ease of install?
    By winterstorm in forum General Tech Discussion
    Last Post: 07-22-2012, 04:16 PM
  2. WTB rear turbo plog, front plog and Z7 Crossover
    By Wotgtp in forum Wanted To Buy - Parts
    Last Post: 02-20-2012, 07:39 AM
  3. Ease of painting a bumper cover?
    By natethegreat in forum Visual/Body Modifications
    Last Post: 02-01-2012, 07:42 PM
  4. HV2 Installation
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 10:09 PM
