Thread: ECU question
Results 1 to 5 of 5
  1. #1 ECU question
    Mar 2018
    Tucson,AZ
    ok, so I have narrowed down my 98 GTP issues to either ecu or wiring. now my question and i do not know why i did not ask this before is....
    should the gtp start with an ecu from a 05 impala ls with the 3.8 non sc and just run like crap, or do i need to try with an ecu from a 98-02....
    i have a 05 impala as my daily and other than swapping coils and some other sensors to see if that was the problem have not attempted the ecu yet. not sure if its worth the 4 bolts to get it out and in the gtp to try.
  2. #2 Re: ECU question
    The 2005 computer is not going to work well. There is a difference in security systems, engine harness wiring for various sensors, injector sizes.
    You'd need an older computer ideally a 98-00 GTP computer as those calibration are nearly the same. 01+ some different emissions related stuff.
  3. #3 Re: ECU question
    GT Level Member mguzzo's Avatar
    Buffalo NY
    your best bet is a 1998 PCM. 98 to 02 will work, 03 will probably start the car but it wont drive well because the trans control is different from earlier. I don't think the 05 will work at all.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  4. #4 Re: ECU question
    you need a 98 pcm, end of story. 04 up dont even have the same plugs on the pcm. so thats really out the window.
    ive loaded up 99, 2000, 01 in my 98 regal, even with they right maf file, still ran like crap, or barely ran.
  5. #5 Re: ECU question
    I would bet a honda ecu would work as well as an 05
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
