Thread: Oil pan gasket help
Results 1 to 7 of 7
  1. #1 Oil pan gasket help
    Donating User
    Jul 2014
    Minnesota
    So I need to change my oil pan gasket as it is leaking, and I was told that you have to drop the subframe a little bit to get the oil pan out. Is there anyone in the Twin Cities area that has donethiss before and would be willing to help please let me know.
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #2 Re: Oil pan gasket help
    Antioch, IL
    I lifted the engine from up above, didnt drop the frame. UNbolted lower motor mount and lifted up, remove mount and m ount U bracket and pan is all yours for the unbolting.
    20160319_173735 by Corey S, on Flickr
    20160319_182010 by Corey S, on Flickr
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Oil pan gasket help
    Donating User
    Jul 2014
    Minnesota
    Hmm interesting, never thought of that way to do it. Just have to find an engine hoist now.
  4. #4 Re: Oil pan gasket help
    Jan 2014
    AR
    I am curious if a lift bar is enough to get the job done.
  5. #5 Re: Oil pan gasket help
    you'll also need to remove the ac compressor, its blocking the two bolts for the U brackets the engine mount bolts too.
    its only 3 nuts on the bracket, then a few more on the back side bracket of the compressor. then once free lay it on the sub frame, no need to take the lines off it.
    i did a smear of rtv on the block, and the pan, then laid the gasket in place. i also used thread sealant on the pan bolts, you'll see that the threads are clear through the block and oil hits them. then the bolts can seep oil over time. 3 years later still bone dry.
    and the oil sensor in the front of the pan, remove that first or you'll break it. install it last too of course.
  6. #6 Re: Oil pan gasket help
    I strapped it up with a 4x4 and chain. dropped sub a little. Either way you want just a little more space than you have. Also .. enjoy the back bolt that is holding one of the knock sensor heat shield. A pivot head ratcheting wrench is by far one of the best tools for this fun job.
  7. #7 Re: Oil pan gasket help
    Donating User
    Jul 2014
    Minnesota
    Good to know, thanks for the help
  1. Head gasket problem, 25 miles on new gasket
    By GTPlzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2014, 04:25 PM
  2. LIM gasket or Head Gasket?
    By Fahrenheit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2013, 06:12 AM
  3. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  4. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  5. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
