Thread: Keep cracking plugs on cylinder 5
Results 1 to 5 of 5
  1. #1 Keep cracking plugs on cylinder 5
    Ohio
    Guys, I keep cracking the porcelain on the #5 spark plug. I've cracked 3 now, and only got 100 miles on the last one. Any idea what is causing this? I'm not beating on the car at all, driving like a grandpa trying to get max economy. Plugs are Delco 41-101. Electrodes are fine, it's just the porcelain. Tried to upload pics to this site, but it says they are too big.
  2. #2 Re: Keep cracking plugs on cylinder 5
    St. Louis
    Are you using an actual spark plug socket to install them? That's the only way I've seen one get a crack in it. Is there something near that plug that could hit it?
  3. #3 Re: Keep cracking plugs on cylinder 5
    Ohio
    Yes, using a spark plug socket. None of the other plugs are cracking. You can tell when it has cracked, as the mileage will drop off and the car will stumble bad on throttle tip-in (like going up a hill and seeing a couple lbs of boost build in 4th gear).
  4. #4 Re: Keep cracking plugs on cylinder 5
    Is there anyway it's hitting something? Being #5 it's right up front. Do you have bad motor mounts, maybe the fan?
    I too can't see why a plug would crack on it's own unless it's getting hit
  5. #5 Re: Keep cracking plugs on cylinder 5
    Ohio
    No, if you look at our motors, the plugs are set back in the manifolds so they are mostly protected from hits. I just pulled the plug back out, and it has no cracks in it. Very carefully put it back in. Will post back if it happens again. Thanks for the replies.
  1. cracking noise after lca
    By 08 gp lvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2015, 09:52 AM
  2. Spark plugs in cylinder 3 keep getting smashed. Pretty sure he spun a bearing
    By acidcrashdburnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2012, 12:56 PM
  3. Static and cracking sound from door and dash speaker
    By DeweyMFD in forum Audio, Security & Visual Electronics
    Last Post: 06-04-2011, 11:14 AM
  4. Outside window seal cracking... Pics
    By chevyy1212 in forum General Tech Discussion
    Last Post: 05-18-2011, 08:58 PM
  5. You Tube Cracking down!
    By David99GTP in forum The Rant Forum
    Last Post: 02-11-2009, 12:32 PM
