Thread: Downpipe and O2 Test delete in HP tuners.
Results 1 to 12 of 12
  1. #1 Downpipe and O2 Test delete in HP tuners.
    SE Level Member Tater85's Avatar
    Dec 2017
    Idaho
    Alright I got myself a scangauge II in December and have been watching my KR along with other info. I am typically seeing 3-4 degrees KR climbing hills and in general at the beginning of acceleration. Sometimes I can see as high as 6 but rarely. My thoughts are that by installing a 3" catless zzp downpipe I could eliminate the KR and get better mileage, car has about 120k on it now so I figure the cat might be getting restrictive. I don't plan to mod this car extensively. It is a 2002 gtp. I have been reading that the zzp Rear O2 emulator will not work on 01 and up, they say otherwise but its all over in this forum that it won't work. I also have been reading that HPtuners will not allow you to delete the rear O2 sensor test that dumps fuel. Help with tuning a series 2 L67
    My concern is that even if I buy a catted downpipe I may still get a cat code. I would like to delete the cat and avoid the issues in the long run that might be experienced like plugging it up etc. I have access to an older version of HPtuners. Does anybody know for sure if it can be used to delete the rear o2 test and not just the resulting codes?
    Or as another option does the bung extender work?
    Asking because it seems none has followed up on solving this issue on an 01 up car.
  2. #2 Re: Downpipe and O2 Test delete in HP tuners.
    buy a off road 3" dp. then have your stock cat in and out lets opened up to 3 inch, cut and weld the cat in place. now the o2 will work as it should.
  3. #3 Re: Downpipe and O2 Test delete in HP tuners.
    Dec 2017
    Idaho
    The point was to get rid of my old potentially clogged up cat. I would rather avoid this since I am not setup to weld stainless and don't want to cut up a brand new downpipe.
  4. #4 Re: Downpipe and O2 Test delete in HP tuners.
    The Boss Iceman6669's Avatar
    Jun 2011
    The anti-fouler truck works iirc. Also I’ve never done it with HPT but I assume you can set the codes the same way as DHP to get the cat diagnostics to work properly. Also I think the rear O2 sim from ZZP might solve the issue.
    2011 F-150 Yote powered
  5. #5 Re: Downpipe and O2 Test delete in HP tuners.
    its the high flow cat thats causing the issue. the o2 sims work, or find a local to tune that out with dhp.
  6. #6 Re: Downpipe and O2 Test delete in HP tuners.
    Dec 2017
    Idaho
    Did they change the o2 emulators for 01 and up in the last 2-3 years? I can find multiple threads around 2015 and older stating they do not work due to gm adding a cat diagnostic test in 01 model years and up.
    http://www.grandprixforums.com/pcm-t...er+PCMs+Things
  7. #7 Re: Downpipe and O2 Test delete in HP tuners.
    Jun 2011
    In order to eliminate cat diagnostics you have to set certain codes to report but not set the MIL iirc. It’s been a few years since I messed with it.
  8. #8 Re: Downpipe and O2 Test delete in HP tuners.
    hpt cant turn off the cat test. no matter what your codes are set to.
    you can dl old hpt find a bin from dhp then alter its vin# to yours. then kill the cat test with tiny tuner. then load and flash it with the old hpt. Change Vin / Serial Number of Bin File
    dhp and hp depository where to find a bin . old hpt tuner software is in the drop box there too.
  9. #9 Re: Downpipe and O2 Test delete in HP tuners.
    Dec 2017
    Idaho
    Well that sucks, maybe I will buy a catted Dp and try the o2 extender bung.
  10. #10 Re: Downpipe and O2 Test delete in HP tuners.
    May 2008
    Schuyler, NE
    Scotty is right. Tiny tuner is the only way you can completely disable the cat test. You may get lucky with the bung extender or o2 simulator, but they don't 100% work.
  11. #11 Re: Downpipe and O2 Test delete in HP tuners.
    Dec 2017
    Idaho
    Where does one obtain a tiny tuner these days. I found a download here The Tiny Tuner. I assume I need DHP tuner in combination with tiny tuner. What type of hardware is needed? Seems like DHP is no longer made so do I need to find it used?
  12. #12 Re: Downpipe and O2 Test delete in HP tuners.
    used is the only way to go now for a dhp. tiny tuner is on line for down load, it might be in that link i posted with the drop box link too. you want v 1.9. it shows the cat diag stuff.
    if it came down to it you could ship me your pcm and i could delete the cat test and make it a canned tune if you wanted for a small fee and shipping back.
    that offer stands for you or anyone else looking for a cat test delete.
  1. Downpipe bolts not sealing downpipe to manifold
    By chicagochuck in forum General Tech Discussion
    Last Post: 12-01-2015, 12:26 AM
  2. WTB ZZP Catted Downpipe or U Bend Delete
    By chrisdaboss in forum Wanted To Buy - Parts
    Last Post: 05-15-2014, 08:31 AM
  3. Lock it up
    By PurpleGuy in forum For Sale - Parts
    Last Post: 09-26-2013, 03:42 PM
  4. WTB Ubend delete or downpipe
    By K Kraziee in forum Wanted To Buy - Parts
    Last Post: 05-18-2013, 11:41 AM
