Thread: Increasing tension on seat belt return
Results 1 to 4 of 4
  1. #1 Increasing tension on seat belt return
    Feb 2018
    texas
    Is there a way to increase the tension on the spring that pulls the seat belt back when you unbuckle it?? Mine will not go in all the way unless you do it by hand every time...I have everything apart right now, and can see nothing visible that is wrong with it, so im assuming the return spring has gotten weak...Thanks
  2. #2 Re: Increasing tension on seat belt return
    St. Louis
    Yep. Replace it with a jy one of the same color.
  3. #3 Re: Increasing tension on seat belt return
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Agreed. The whole assembly is held together with rivets and designed not to be tampered with. You really don't want to mess with something that important.
  4. #4 Re: Increasing tension on seat belt return
    Feb 2018
    texas
    Makes sense...
  1. How much tension should supercharger belt have?
    By wmorrison65 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2015, 08:36 PM
  2. Help with 2006+ seat swap into 1998 seat belt issues
    By ebk231 in forum General Tech Discussion
    Last Post: 05-15-2014, 01:43 PM
  3. Timing Chain/Belt replacement? Tension-er replacement?
    By void33 in forum General Tech Discussion
    Last Post: 02-21-2014, 02:34 PM
  4. Seat belt windups
    By PurpleGuy in forum General Tech Discussion
    Last Post: 02-25-2011, 12:22 PM
  5. seat belt ?
    By crewsn in forum General Tech Discussion
    Last Post: 04-17-2009, 10:19 PM
