Thread: Did Parts Store Give Me Wrong L67 Spark Plugs?
Results 1 to 7 of 7
  1. #1 Did Parts Store Give Me Wrong L67 Spark Plugs?
    SE Level Member ELECTRICxWIZARDx's Avatar
    Sep 2017
    SW Oklahoma
    First, yes I did search previous threads, but found much conflicting info/opinions.
    '01 GTP, bone stock. 151k miles.
    Car currently has ACDelco 41-101 Iridiums installed. https://www.summitracing.com/parts/ado-41-101
    O'Reillys dude sent me with ACDelco Professional 41-902 https://www.summitracing.com/parts/ado-41-902
    Owner's Manual says OE spec calls for NGK Type PTR4B-15 https://www.summitracing.com/parts/ngk-5146
    I even went back in to double check, I didn't remember the part number for the iridiums offhand, but knew it didn't sound right.
    Now, from what I've read, plat plugs don't agree with waste-spark ignition systems, or forced induction. Check, and check.
    So, go ahead and install the double plats i have, or go return them for the 41-101s, or something else you guys recommend?
  2. #2 Re: Did Parts Store Give Me Wrong L67 Spark Plugs?
    Th 41-902's are a factory plug for GM cars but not one I would run in a 3800.
    Stick with the 41-101's.
  3. #3 Re: Did Parts Store Give Me Wrong L67 Spark Plugs?
    Sep 2017
    SW Oklahoma
    Thanks, good to know. Durka Durka.
  4. #4 Re: Did Parts Store Give Me Wrong L67 Spark Plugs?
    Kemmerer, Wyoming
    oooh durka durka durka muhommed jihad
  5. #5 Re: Did Parts Store Give Me Wrong L67 Spark Plugs?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    stock plugs are PTR-4B which are platinum. Even stock you can safely run a TR55ix and it will work fantastic.
    IMHO if you drive like its a stock car and don't beat on it, plugs don't matter, use a recommended cross reference to stock.
    if you start modding then plugs start to matter.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #6 Re: Did Parts Store Give Me Wrong L67 Spark Plugs?
    Sep 2017
    SW Oklahoma
    Quote Originally Posted by mguzzo View Post
    I try to, but easier said than done. Usually end up getting into the boost once or twice on a 15mi drive into town. That sweet sweet blower whine is addictive.
    Anyway, went ahead and returned the plats for 41-101s this morning. Judging by the condition of the old ones, motor seems pretty happy with them. Now just waiting for a new coupler to come in to get rid of the rattle at idle.
    Off topic, but whats a normal idle rpm range? Mine starts around @ 1300, then settles down to 1k-1100 after a few seconds. But, also found a few worn vacuum fittings while i was in there, gonna finish tracing vac leaks tomorrow.
  7. #7 Re: Did Parts Store Give Me Wrong L67 Spark Plugs?
    It's coolant temp dependent of idle rpm, the colder the temp the higher the revs.
    1300 on cold start sounds normal and then slowly down to 1000ish but once you are over 80-100 degree coolant temps it should be way down to around 750.
  1. Spark Plugs
    By MrDniceL36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2014, 07:46 PM
  2. Maintenance gone wrong - wires/plugs - NOT RUNNING
    By HEVEYMETIL in forum General Tech Discussion
    Last Post: 04-10-2013, 02:00 PM
  3. Spark plugs!!!
    By tlawnewtograndprix in forum General Tech Discussion
    Last Post: 03-28-2013, 12:29 AM
  4. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  5. Spark Plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2008, 10:45 PM
