Thread: How can i make my monsoon sound system have more bass
Results 1 to 4 of 4
  1. #1 How can i make my monsoon sound system have more bass
    Apr 2017
    IN
    2004 GT2 with the 6cd disc changer and the monsoon sound system. I have the stock speaker set up, stock amp, stock etc. Haven't done anything to it. I want to make it have more bass. I have no idea how sound systems work or anything like that. I am wondering if i purchase bigger subs, how would I hook them up, etc etc. Should I just have someone do it for me? Thank You!!!
  2. #2 Re: How can i make my monsoon sound system have more bass
    St. Louis
    I'd likely remove stock speakers/HU, run new speaker wire, get an aftermarket headunit, a 4 channel amp, steering wheel adapter and whatnot to retain chime (if you have it) and steering wheel controls, install. You could install another amp and a sub if you want to while you're at it.
    The Monsoon system is its own animal and not really worth upgrading from what I've read.
  3. #3 Re: How can i make my monsoon sound system have more bass
    Aug 2016
    CT/RI Border
    Infinity speakers. Step 1 in monsoon if you do not want a full system rewire is replace your rears with infinity component speakers.
    You can also hijack the bass signal going into the monsoon, T off of it and add another amp/sub(not recommended).
    Sent from my ASUS_Z00TD using Tapatalk
  4. #4 Re: How can i make my monsoon sound system have more bass
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Your best bet is just to add a small powered sub or an amp and sub.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  1. Thoughts on Monsoon Sound System ?
    By Pete67 in forum General Grand Prix Discussion
    Last Post: 04-02-2017, 09:52 PM
  2. No sound after radio install..2004 Monsoon system. Need quick help
    By nickleahy23 in forum Audio, Security & Visual Electronics
    Last Post: 06-13-2012, 08:47 PM
  3. Looking for good sound and bass
    By Amb4 in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2010, 06:04 PM
  4. Need help with Monsoon sound system please
    By Keith04gp in forum General Tech Discussion
    Last Post: 09-29-2008, 04:51 PM
