Ok, I have been diagnosing this all day for 3 days now. I have no blower motor on any setting.
Here is what I have done;
Tested voltage at blower motor. I got .8v on full speed, and 2.4v on lowest setting(same when off).
Tested voltage going into resistor/blower motor control module. I got full 12.9 volts using the ground on the plug. So power and ground on the plug are good.
Replaced resistor. Still nothing. After I replaced resistor I checked voltage at the blower motor again to see if maybe blower motor was bad too and I got the exact same readings as before.... .8v on high and 2.4v on low.
Replaced motor for the hell of it with a known good one and got nothing.
Replaced switch controls for the hell of it and got nothing. No change.
Replaced connectors and wires for resistor and blower motor, I though maybe a wire fried in one of the connectors. No change.
WHAT AM I MISSING???!
Thanks in advance!
