Thread: 02 gp gt tranny cooler lines leaking?
Results 1 to 6 of 6
  1. #1 02 gp gt tranny cooler lines leaking?
    Sep 2015
    Lansing, Michigan
    Was replacing the condenser and radiator and I twisted the tranny cooler lines and now they're both dripping tranny fluid. They were wet before I even touched the radiator.
    Auto zone and o Reilly's only have the lower line. I need both. Should I call the dealer?
  2. #2 Re: 02 gp gt tranny cooler lines leaking?
    St. Louis
    Where did you twist them? At the trans?
  3. #3 Re: 02 gp gt tranny cooler lines leaking?
    Sep 2015
    Lansing, Michigan
    i pulled the junk radiator up with the lines still attached so I could unhook them from the radiator. after that I held the lines against the front of the engine as i was replacing the radiator and condenser. they are horribly rusty. i think ac delco # 10330106 is the line i need not sure. i need the upper cooler line. all the parts stores around sell just the lower line and i need both
  4. #4 Re: 02 gp gt tranny cooler lines leaking?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    They rust out just like the fuel and brake lines, I would replace them.
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  5. #5 Re: 02 gp gt tranny cooler lines leaking?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Rockauto.com has fast shipping
    DORMAN 624968 {#10330105} Info
    Lower
    $24.89
    ACDELCO 10330106 GM Original Equipment Info
    Upper
    $32.89
    ACDELCO 10330105 GM Original Equipment Info
    Lower
    $33.79
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  6. #6 Re: 02 gp gt tranny cooler lines leaking?
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    This thread might help. Sounds like a similar problem:
    http://www.grandprixforums.net/threa...Power-steering
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  1. cooler line adapters for tranny cooler.
    By Sandman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2013, 01:28 PM
  2. cooler lines
    By dlk in forum General Grand Prix Discussion
    Last Post: 01-06-2013, 08:21 PM
  3. converting tranny cooler lines from 1st design to 2nd design
    By tonglebeak in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2012, 08:16 PM
  4. Trans cooler lines are leaking
    By gpse2000 in forum General Grand Prix Discussion
    Last Post: 07-06-2012, 06:31 AM
  5. Tranny lines for trans cooler
    By monsterjam5000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-12-2010, 04:09 PM
