Thread: Missfire from 2-1 Downshifts 6-9* kr.
Results 1 to 2 of 2
  1. #1 Missfire from 2-1 Downshifts 6-9* kr.
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Hey all,
    So when I downshift from 2-1, I get some hesitation and it sounds like misfires and anywhere between 6-9* of kr. I also have to fault codes, P1571 (Traction Control Desired Torque Out Of Range) (the abs/traction light is on due to a bad wheel speed sensor) and P1260(Fuel Pump Speed Relay Control Circuit Conditions, key on or engine running, then the PCM detected an improper voltage level on the Fuel Pump Speed Control PWM circuit, condition met for at least 30 seconds). The mods are new(put in today) Al 104's (gapped to .052), 3.4 pulley, overkill tune, headers, 180 tstat. I think the NAPA wires have around 40k miles and the coil packs had a resistance measured around 6k+-0.05.
    Thanks,
    Chris
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Missfire from 2-1 Downshifts 6-9* kr.
    Jun 2012
    Illinois
    Update, did some pulls today and it seems to be getting much better. Will update more.
  1. Rebuilt trans, Very Harsh Downshifts (Tap shift)
    By gagt3100 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-29-2012, 11:21 AM
  2. Late Downshifts
    By winterstorm in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-11-2012, 04:56 PM
  3. downshifts 2 gears then SES for 5-10 seconds
    By infarno in forum General Tech Discussion
    Last Post: 04-20-2012, 11:03 AM
  4. 91 Grand Prix 3.1L hard upshifts / downshifts
    By neorules in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 11-18-2011, 09:09 AM
  5. 4-1 and 3-1 downshifts
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2010, 07:46 PM
