Thread: Freon+working compressor= no cold air??
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Freon+working compressor= no cold air??
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    if you don't properly oil balance the compressor during replacement, the compressor is oil starved and it last about 1 season.
    2004 comp g
  2. #22 Re: Freon+working compressor= no cold air??
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Oil balance? We just followed the directions on the compressor which was to add 3oz of oil because it comes "primed".
    Sent from my LG-H918 using Tapatalk
  3. #23 Re: Freon+working compressor= no cold air??
    Nov 2012
    Madison
    Quote Originally Posted by suitercrew View Post
    It did not hold pressure at 30hg but the gauges we were using were leaking so there was no for sure way to leak test the system. Considering we just installed a whole brand new system last October, put new seals/orings and it worked for 2 months before randomly not working one day me and my dad are very hopeful it was just the compressor.
    You have to make sure. Moisture in a refrigerant system is a no-no. Could be why your compressor died.
    But anyway hopefully all works out for you
  4. #24 Re: Freon+working compressor= no cold air??
    Sep 2013
    Calgary, Alberta
    As long as you followed the instructions (in regards to oil balancing) that came with the compressor you should be fine. Each major component (evap, condenser, accumulator, compressor) has a oil volume that resides in each part as oil circulates in suspension with the refrigerant. that volume should be added when the part is replaced. the total system volume may be 6 oz with 3 of it existing in the compressor sump.
    The question is why did the new compressor fail?
    gm dealers have a filter screen kit; installed on the compressor inlet to protect the new compressor after a compressor failure. If you have another failure, install the screen.
    and yep, moisture and refrigerant form acid...
    2004 comp g
  5. #25 Re: Freon+working compressor= no cold air??
    Oct 2015
    Wait.. so do you add oil to the compressor itself AND through the low side port?
  6. #26 Re: Freon+working compressor= no cold air??
    Sep 2013
    Calgary, Alberta
    yes. When oil balancing the compressor, oil is added or removed from the compressor and then the compressor is installed. oil for other components can be added to the low side port.
    instructions vary to determine the amount to add or remove, so i always follow the directions that come with the compressor.
    for example: one company may want you to drain the old compressor and add that volume of new oil to the new compressor. If nothing comes out, add 3 oz.
    2004 comp g
  7. #27 Re: Freon+working compressor= no cold air??
    Oct 2015
    Well I didn't put oil in through the low side.. How much do I need to put in?
  1. Does low Freon shut off the compressor?
    By suitercrew in forum General Tech Discussion
    Last Post: 05-11-2017, 02:13 PM
  2. Help with freon leak 99 GTP
    By hshift in forum General Tech Discussion
    Last Post: 08-13-2016, 02:48 PM
  3. Freon/AC
    By jaydasparkz in forum General Tech Discussion
    Last Post: 07-21-2011, 05:28 PM
  4. Freon Charging
    By GreyGhost in forum General Tech Discussion
    Last Post: 03-27-2011, 04:30 PM
  5. AC only takes 7oz of freon?
    By SuperSport in forum General Tech Discussion
    Last Post: 07-07-2009, 06:39 PM
