Thread: Does low Freon shut off the compressor?
Results 1 to 4 of 4
  1. #1 Does low Freon shut off the compressor?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys it's getting time to fix the a/c before summer. Maybe 6 months ago I replaced the whole system and It worked great for a few months then randomly only blows hot air. I've heard some vehicles compressor won't turn on if there's low Freon in the system. Because my compressor does turn on but no cold. I'm assuming I just have a leak (probably under the stupid brake booster) but would like peoples opinions. Thanks
    Sent from my LG-H901 using Tapatalk
  2. #2 Re: Does low Freon shut off the compressor?
    Pennsylvania
    Yes, there's a low and high cutoff switch that if the pressure in the system goes too high or low the compressor will not run.
  3. #3 Re: Does low Freon shut off the compressor?
    Oct 2015
    If air got into the system couldn't the pressure still read high even If it was low on Freon?
  4. #4 Re: Does low Freon shut off the compressor?
    HUDSON
    First thing to do is get some 134a gauges and check the pressures.
  1. Help with freon leak 99 GTP
    By hshift in forum General Tech Discussion
    Last Post: 08-13-2016, 02:48 PM
  2. Freon/AC
    By jaydasparkz in forum General Tech Discussion
    Last Post: 07-21-2011, 05:28 PM
  3. Freon Charging
    By GreyGhost in forum General Tech Discussion
    Last Post: 03-27-2011, 04:30 PM
  4. A/C Freon leak
    By BlackandSilverGTP in forum General Tech Discussion
    Last Post: 04-07-2010, 07:54 AM
  5. AC only takes 7oz of freon?
    By SuperSport in forum General Tech Discussion
    Last Post: 07-07-2009, 06:39 PM
