Thread: Can you wire sub/amp wire to fuse box or alt?
Results 1 to 5 of 5
  1. #1 Can you wire sub/amp wire to fuse box or alt?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Sent from my LG-H918 using Tapatalk
  2. #2 Re: Can you wire sub/amp wire to fuse box or alt?
    dutchess county,n y
    i would wire it directly to Battery and put an inline fuse on the wire . or at the terminal right near battery
  3. #3 Re: Can you wire sub/amp wire to fuse box or alt?
    Oct 2015
    Ya I was just having an issue fitting the main cable plus the hid relay harness, intercooler pump harness, and 8 gauge amp wire on the tiny ass side plug. Anyway I went to autozone and they has this really nice gold plated battery bolt that had a 2nd post on it so I now have the hid harness and main harness on the main post and then put the sub and intercooler pump on the secondary post. Its working great now
  4. #4 Re: Can you wire sub/amp wire to fuse box or alt?
    Quincy, Mass
    I used the post on the fuse box myself. Side terminal batteries suck.
    No more GP 04 Impala SS Indy:
  5. #5 Re: Can you wire sub/amp wire to fuse box or alt?
    i got my amp power wire on the fuse box cable bolt, and the power on wire in the in car fuse box to a key on fuse, aka the wipers with a add a fuse.
  1. Looking for some speaker wire and a new ground wire.
    By Bluemagic in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 08:41 PM
  2. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  3. in-line amp wire fuse holder set screws
    By Dee23 in forum Audio, Security & Visual Electronics
    Last Post: 12-29-2012, 01:23 PM
  4. Replies: 8
    Last Post: 10-28-2012, 03:58 AM
  5. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
