Back when I got my new tranny installed, the shop told me I had a leak in the coolant line leading to the AC setup. Here is the mess Hopefully it will be an easy fix!
In regular light, you really cant see the leak, it almost looks normal....
But when I threw some LED light on it, the UV dye showed up pretty good.
That will be my next little project after getting some other things squared away.
