Thread: Help with poly mounts
Results 1 to 5 of 5
  1. #1 Help with poly mounts
    SE Level Member Royalblue's Avatar
    Waldorf, MD
    Doe's anyone know how to get the stock rubber mount out of bracket on radiator side & is it better to unbolt it first
  2. #2 Re: Help with poly mounts
    cut them with a sharp knife and pry em out with a screw driver.
  3. #3 Re: Help with poly mounts
    Waldorf, MD
    Thanks for the advice. I tried to beat it with a hammer with the bolt still in it. I'll get a sharp knife and cut it out.
  4. #4 Re: Help with poly mounts
    GTP Level Member buickman104's Avatar
    NYC
    I burned mine out.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: Help with poly mounts
    GTP Level Member Rlugo87's Avatar
    Jun 2016
    Minnesota
    I had to cut mine out.
    Sent from my LGL82VL using Tapatalk
  1. Poly dog bone bushings, poly motor mounts, couple misc pieces
    By SomeDudeAtHome in forum Wanted To Buy - Parts
    Last Post: 05-08-2014, 05:43 PM
  2. Poly Mounts from ZZP
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-10-2009, 05:11 PM
  3. Go poly mounts!!!
    By gotboost3 in forum General Tech Discussion
    Last Post: 04-22-2009, 03:02 PM
