Thread: Timing cover relearn
Results 1 to 4 of 4
  1. #1 Timing cover relearn
    Sep 2015
    IL
    When replacing the timing cover gasket, someone on here said there's a 50/50 chance you actually need to perform the relearn procedure. Could I replace the gasket and drive somewhere to have a mechanic do the relearn? How much would that cost? Probably less than even the cheapest scan tool that has the capability of doing that I'm assuming..
  2. #2 Re: Timing cover relearn
    id not worry about, just make sure the crank sensor is tq'ed right when the cover is re installed.
    if you need one the cel will come on. and it will still drive.
  3. #3 Re: Timing cover relearn
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Yeah I'm with scott. I wouldn't worry about it. I've had my timing cover off about 3 times with no need for a case relearn or anything like that.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  4. #4 Re: Timing cover relearn
    Sep 2015
    IL
    good to know, thanks
  1. Coolant leak from the Timing cover.
    By Springer09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-26-2016, 10:31 AM
  2. Timing Cover
    By xcwilli11 in forum Wanted To Buy - Parts
    Last Post: 01-23-2016, 10:55 PM
  3. Timing Chain cover
    By brichter45 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-08-2013, 12:11 PM
  4. timing cover gasket confusion
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2012, 09:37 AM
  5. Timing Chain cover
    By timboku in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2010, 10:02 PM
