Thread: Constant clicking noise in cabin.
Results 1 to 10 of 10
  1. #1 Constant clicking noise in cabin.
    GXP Level Member suitercrew's Avatar
    Oct 2015
    I continuously hear this constant clicking noise inside my car. Its very faint. If I had to describe it I would Say it sounds like the blend door actuator constantly switching around. It does it with all the air turned off, maybe with it turned on too but it's so quiet with it on you wouldn't be able to hear it? So is this a blower resister thing? The actuator itself? Or maybe a vacuum leak? I should also tell you that all my hvac controls seem to work fine. Thanks for the help.
    Sent from my LG-H901 using Tapatalk
  2. #2 Re: Constant clicking noise in cabin.
    Sep 2015
    Cheyenne, WY
    Crickets!
  3. #3 Re: Constant clicking noise in cabin.
    you'll have to reach under the dash and touch the actuators to feel if they are the sound, they can freak out and work back and fourth on ya.
  4. #4 Re: Constant clicking noise in cabin.
    Oct 2015
    Quote Originally Posted by LEVELX View Post
    Crickets!
    So if it is the actuator making the noise. Is the actuator broken or could it be other things making it switch back and forth?
  5. #5 Re: Constant clicking noise in cabin.
    they like to break. could be the motor getting retarded. or a busted gear its trying to keep turning.
  6. #6 Re: Constant clicking noise in cabin.
    SE Level Member dirtyape's Avatar
    Dec 2014
    Lomita,Ca
    In the first yr or so of owning my 97, i had a similar thing. turned out to be my speedometer cable was loose.
  7. #7 Re: Constant clicking noise in cabin.
    Quote Originally Posted by dirtyape View Post
    i find that so hard to believe, considering you dont have a speed o cable.
  8. #8 Re: Constant clicking noise in cabin.
    Dec 2014
    Lomita,Ca
    really? is there a cable to the mileage counter? or the tach? it has been 20yrs so i dont exactly remember. the mechanic said it was a cable going to something in the instrument cluster.
  9. #9 Re: Constant clicking noise in cabin.
    GT Level Member mguzzo's Avatar
    Buffalo NY
    blend door actuator. mine creaks and groans. I'll probably crawl under there and give it a shot of silicone spray to see what happens.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  10. #10 Re: Constant clicking noise in cabin.
    old cars yes, the gp is all digital. nothing but a plug in the back of the cluster.
  1. Extremely loud cabin noise
    By LiveOutLoud in forum General Grand Prix Discussion
    Last Post: 05-13-2015, 12:10 PM
  2. HELP!! Clicking noise
    By Steven Monteith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2013, 05:21 PM
  3. VERY LOUD noise coming from inside the cabin
    By Fox in forum General Tech Discussion
    Last Post: 05-17-2012, 10:16 AM
  4. buzzing airplane like noise in cabin
    By 2001GrandPrixGT in forum General Tech Discussion
    Last Post: 11-02-2010, 07:31 PM
  5. clicking noise
    By whitegtp in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 05:11 PM
