Thread: Door lock rod clips
Results 1 to 2 of 2
  1. #1 Door lock rod clips
    Aug 2015
    United States
    I'm looking for a very specific clip for my car - or perhaps a solution to the issue with my existing clips.
    On my 2002 GP GTP, the passenger door lock switch has been "sticky". So I pulled off the door panel and the lock mechanism seems fine, but I think I narrowed the problem down to the fact that the lock rod has "play" within the clip that holds in on the door at approximately its midpoint. Here is an example of the clip I'm referring to (highlighted with red): https://ibb.co/h0QQyv
    Searching the internet, I only find results for "Door Lock Rod Clip" none of which seem to be this particular clip: http://shop.advanceautoparts.com/p/d...473/22190045-P
    I've temporarily fixed the problem by shoving some plastic wires into the piece so the rod moves more straightly, but I'm wondering if anyone else has ever had this problem or if a replacement plastic piece would fix the issue? I haven't checked the driver's side yet to see how that clip fits the rod...
    Results online for "sticky door lock" only tell me that my locking mechanism is broke, which it isn't.
  2. #2 Re: Door lock rod clips
    Jul 2010
    Coquitlam,BC,Canada
    The part you need would be had from a junk yard, and maybe the dealer. Check the for sale section here as there are some cars being parted out.
    The "door rod lock clips" are what attaches the rod to the handle or lock.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. 99 GPGT Passenger inside door lock and key lock not working at all.
    By 71gs3504sp in forum General Tech Discussion
    Last Post: 07-26-2016, 04:55 PM
  2. How To Remove Door Panels/Replace Door Panel Clips
    By SubwayGuy in forum How To Write-Ups/Tech Tips
    Last Post: 05-28-2016, 02:43 PM
  3. Door Lock Actuator Replace - Now doors won't electronically lock
    By rmortime in forum General Tech Discussion
    Last Post: 11-17-2012, 12:37 AM
  4. Door Clips!
    By Wrongwayislost77 in forum General Tech Discussion
    Last Post: 07-04-2011, 03:26 PM
  5. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
