Thread: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    SE Level Member BigBadjohn's Avatar
    Dec 2010
    So IL
    The back of my GTP has been sitting low the last few years, I haven't been able to turn my traction control on for over 4 years, I have a lot of road noise in the car especially in the back, and now my car seems to rock side to side at low speeds. My car has over 180k miles so it's time for the suspension to get a much needed rebuilding.
    I bought all of the following parts last night for almost $1200. I was waiting for shocktober to come around again for the Monroe quick struts to get one for free.
    Dorman left lower control arm
    Dorman Right lower control arm
    (2) Dorman front wheel hub assemblies
    (2) Dorman rear wheel hub assemblies
    Dorman Rear stabilizer bar
    (2) Dorman front strut/coil assemblies
    Dorman Left rear strut/coil assembly
    Dorman Right rear strut/coil assembly
    (2) Moog tie rod ends
    Wix transmission filter
    Wix XP oil filter
    Wix air filter
    Wix fuel filter
    Gates serpentine belt
    Gates accessory serpentine belt
    Airtex water pump
    (2) Dorman front hydraulic brake hoses
    (2) Dorman rear hydraulic brake hoses
    (4) Brake hose clips
    2002 Grand Prix GTP 40th anniversary sedan
  2. #2 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    GTP Level Member
    Aug 2012
    st louis park, MN
    Hope it rides tight and true after all that maintenance!
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  3. #3 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    You use a 5% off coupon?
  4. #4 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Dec 2010
    So IL
    No, I didn't know they had promo codes
  5. #5 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    I would have atleast figured out if you really needed all those parts before buying them, you may or may not have needed all 4 wheel bearings and I do expect those dorman units to last very long. Lower quality bearings get eatin up fast.
    And I wouldnt run a airtex water pump, I wouldnt run a airtex anything in any vehicle I own. They are hit and miss on quality and all of their fuel pumps fail rather quickly.
  6. #6 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Dec 2010
    So IL
    Well the wheel hubs I figured to troubleshoot and replace one through a mechanic was the cost of buying two of them and doing it yourself. I know the ABS fault (which is why I haven't been able to turn my TCS on in 4 years) was one of the front ones because when it first started doing it, unplugging and plugging the front two back in would fix it temporarily. Now I have noise in the back and the back of my car has wobble side to side at low speeds sometimes so one or both of the rear hubs is actually failing and not just a sensor. I figure if I plan on driving this car for eternity, replacing most of the parts with lifetime is a good idea. I did that with my brakes about 5 years ago and so far I've replaced the pads in the front once, the pads in the back once, and the rotors in front once. All for free. Sure it sucks having to take the time to do it but I like knowing if they wear out or warp, it costs me nothing but my time
    The airtex water pump looked identical to the picture of the lifetime pump that Oreilly's sells for twice the money and is rebranded. The pulley bolts were even in the exact same position in the picture
  7. #7 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Buffalo
    You better get a magnet
  8. #8 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Dec 2010
    So IL
    What do you mean, I better get a magnet?
  9. #9 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Apr 2015
    Quote Originally Posted by BigBadjohn View Post
    You can find them online everywhere, and with a bill of just about $1200, 5% could've gone a long way...
  10. #10 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Why rear dorman bar its smaller than stock? Should have went with a GMPP
    2012 F150 STX
    - Gonna be a race truck
  11. #11 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Buffalo
    Guys I know things he bought could've should've would've been better then others but give the guy a break. He took initiative to do this on his own with out a 36 page thread of questions.
    I think it's a great start. Live and learn.
  12. #12 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Dec 2010
    So IL
    How much smaller?
  13. #13 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Dec 2010
    So IL
    Someone said something earlier about needing a magnet. Can anyone please explain?
  14. #14 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Buffalo
    did your order come in yet? IF NOT, just wait
  15. #15 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Apr 2012
    Dayton, OH
    How much smaller?
    3mm according to Boobs
    2012 F150 STX
  16. #16 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I thought the 5% code for rockauto was just common knowledge these days? That's $60 (depending if that $1200 was before or after shipping). Wonder if it's possible to amend the order, worth an email or two to ask imo.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  17. #17 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    SWPA
    Quote Originally Posted by 99GT2dr View Post
    I would have thought that searching for coupon codes for any online vendor was common knowledge these days.
  18. #18 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Dec 2010
    So IL
    Ateast it wasn't any $100 I screwed myself out of. Probably would have been $50 or a little more but in the long run I saved $600-$800 vs buying everything from Oreilly's
  19. #19 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    Dec 2010
    So IL
    Quote Originally Posted by SallyBabe03 View Post
    Haha yeah. I see now. I've gotten a few different shipments so far and have gotten two magnets so far. I'm still missing the control arms, air filter, trans filter, oil filter, front wheel hubs, rear stabilizer bar, and water pump so I've probably got at least two more magnets coming. They look cool but the paper seems to peel off the first time you take the magnet off the fridge
  20. #20 Re: Just spent almost $1200 at Rock Auto. V. Suspension rebuild
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    They send a fridge magnet with a car photo submitted by a Rock Auto customer with each order. Here's the beer fridge in my garage:
  1. TYC & Rock Auto
    By Adidasdude1989 in forum General Grand Prix Discussion
    Last Post: 04-10-2014, 12:10 PM
  2. MAF Sensor On Rock Auto
    By indygrandprix in forum General Grand Prix Discussion
    Last Post: 11-09-2013, 04:36 PM
  3. Catalytic Converter from Rock Auto
    By GTLGDP in forum General Tech Discussion
    Last Post: 05-21-2012, 04:56 PM
  4. Rock Auto Discount
    By jshifti33 in forum Off Topic Discussion
    Last Post: 08-19-2009, 12:04 PM
  5. Rock Auto Discount Code
    By TDCRacing in forum Off Topic Discussion
    Last Post: 01-21-2009, 12:35 PM
