Thread: HVAC help
Results 1 to 16 of 16
  1. #1 HVAC help
    Edmond,Ok
    i went to change the direction setting and it is stuck on defrost. it wont change at all. how can i fix this?
    AKA: 1997grandprixkid on CGP
  2. #2 Re: HVAC help
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    sounds like you have a vacum leak that door is controled by vacuum check around the battery thats where they normaly are leaking
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  3. #3 Re: HVAC help
    GrandPrix Junkie
    Saraland Alabama
    any work done to the car recently?
  4. #4 Re: HVAC help
    Edmond,Ok
    i installed a Wizaired CAI a little over a week ago. this just started yesterday
  5. #5 Re: HVAC help
    GXP Level Member Zef_66's Avatar
    PA
    I would agree that you need to check for a vacuum leak. The most common spot is under the battery / fuse box area. This is where I found mine.
    I think there is a vacuum line coming from the top of the engine, going to the pass side strut tower, and running down next to the fuse box. This line will feed into a T fitting. One line of the T fitting will go into the pass compartment and control the HVAC controls. Follow this line all the way around and check for leaks or breaks. This is how I found mine anyway.
    2001 GSE
  6. #6 Re: HVAC help
    Edmond,Ok
    Quote Originally Posted by Zef_66 View Post
    what does this line look like? is it a rubber hose or a hard plastic line?
  7. #7 Re: HVAC help
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    i think it's a hard plastic.... but zef will confirm
  8. #8 Re: HVAC help
    wamego,KS
    it is a hard palstic
  9. #9 Re: HVAC help
    Edmond,Ok
    yep, found it. didnt even really have to look. it was snapped completly apart at the clippy on the strut tower. i feel like an idiot
  10. #10 Re: HVAC help
    wamego,KS
    don't feel like an idiot i had the same problem but i even looked at that line like shouldn't this be connected lol. then it dawned on me the next day.
  11. #11 Re: HVAC help
    PA
    Sorry, just getting around to answering now. But yes, they are hard plastic lines. I had a section of a couple inches missing. I used some rubber vacuum line that fit snug over the plastic vacuum line. Used heat shrink tubing on the ends, and then some silicone RTV on top of that. Works fine for me!
    2001 GSE
  12. #12 Re: HVAC help
    SE Level Member AmericaFcukYeah's Avatar
    May 2008
    This is exactly what is wrong with my car right now! Good thing I looked all the way through and found this thread and another one cause I was just about to post this same question. The search function does not work for me for some reason.
  13. #13 Re: HVAC help
    May 2008
    I went outside with a flashlight and everything seemed to look ok but I'll do a more lengthy search tomorrow hopefully a vacuum leak is the culprit.
  14. #14 Re: HVAC help
    May 2008
    so I've been out there for a couple hours now and I can't find anything. I've ran my fingers down all the lines and still nothing. I also traced the one into the firewall but it looked and felt pretty solid, although I didn't cut the plastic covering for about 14 inches of it. I'm going to get a vacuum tester and check, but in the mean time does anyone have any suggestions. Thank you
  15. #15 Re: HVAC help
    May 2008
    Alright I've been outside all day working on my vehicles and I finally found the culprit in the defrost only crime. Behind the glove box in the passenger floorboard there is a vacuum box almost directly up against the firewall. Theres like 5 colored vacuum hoses coming out of it and the purple one was pinched up against another cluster of wires. I pulled the extra slack through and zip tied the cluster away and it works perfectly. So far easy fixes on this car and I'm doing the body work next week and going to undercoat the underbody cause the rocker panels are rusty.
  16. #16 Re: HVAC help
    ma.
    Just found this site and boy....what a find. I had no control over ac/heat vents. Thanks to threads by MTXGTP, ZEF-66, and3800 SE, I have fixed the problem ( vacuum hose break under the fuse box.) Also repaired the water deflector that was leaking water onto the passengers side floor. Thanks guys.
