Thread: Door hinge
Results 1 to 13 of 13
  1. #1 Door hinge
    SE Level Member Lawenforcer's Avatar
    Shelbyville, IL
    Hello All. I took my door off my 2000 2 door GT, cause the sagging. I bought the rebuild kit to rebuild it but come to find out the bigger long pin that holds it together is snapped. So I need to replace the pin. Can you buy just the pin that fit's it. I am unsure what size it is so I don't want to order the wrong one. I also hate to order used hinges cause they would still need rebuilt I'm sure. Please help. I need to get this door back on...
    2000 Grand Prix GTP
  2. #2 Re: Door hinge
    http://www.grandprixforums.net/threa...-with-new-PINS thi sis all i know of for pins. if the long one on the door side broke i think you need that whole part bolted to the door.
  3. #3 Re: Door hinge
    Shelbyville, IL
    I was trying to upload a picture to show the problem but I can never get the pics to upload on my phone...
    2000 Grand Prix GTP
  4. #4 Re: Door hinge
    this part? its th only long shaft.
  5. #5 Re: Door hinge
    Shelbyville, IL
    Yes...it's that one. Mine is completely broke in two...
    2000 Grand Prix GTP
  6. #6 Re: Door hinge
    Shelbyville, IL
    This is the problem...
    2000 Grand Prix GTP
  7. #7 Re: Door hinge
    id grab a used one from a junk yard.
  8. #8 Re: Door hinge
    GT Level Member mguzzo's Avatar
    Buffalo NY
    ^^ agree, put on a set of good condition hinges. I ended up replacing my hinges then shimming a little to get the swing and closing correct.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  9. #9 Re: Door hinge
    Shelbyville, IL
    Okay. They wanted $80 there at the local junk yard so wasn't sure if I could buy just that pin...
    2000 Grand Prix GTP
  10. #10 Re: Door hinge
    Antioch, IL
    A welder could fix that in 30 seconds.
    2009 Challenger SRT8
    Expert at being gay.
  11. #11 Re: Door hinge
    80 for 1/2 a hinge? f that crap.
    theres parts outs listed here. any 97-03 hinge will work.
  12. #12 Re: Door hinge
    Jan 2014
    AR
    That doesn't sound like a "you pull it" junkyard price, but a salvage hinge with your new bushing kit in it would normally be the easiest solution. Now that the pin is broken, the spring might be missing. Putting the spring in can be tricky so yeah I'd opt for a salvage hinge if available. But the "door roller pin" (your search term), which I usually call the detent roller, is available seperately but its a GM part and its a common one if I'm researching correctly. Under $10. Shared part with S-10s. If I were you, I'd stick the door back on and use it without detents, carefully, until you can locate a part.
  13. #13 Re: Door hinge
    Buffalo NY
    in a pinch you could swap with the passenger side. The hinges are the same left and right, just swapped top and bottom.
  1. 4 door hinge repair?
    By Fahrenheit in forum General Tech Discussion
    Last Post: 04-19-2015, 06:52 AM
  2. Door hinge help
    By blortz in forum Visual/Body Modifications
    Last Post: 09-18-2014, 10:16 AM
  3. HELP HELP! 99 grand prix 2 door DOOR HINGE REPLACEMNT
    By blortz in forum General Tech Discussion
    Last Post: 05-31-2011, 08:52 PM
  4. door hinge roller wheel
    By dougf in forum 04+ Specifics
    Last Post: 02-24-2011, 09:42 PM
  5. door hinge / pins
    By hourang in forum General Tech Discussion
    Last Post: 12-11-2010, 12:27 PM
