Thread: vacuum hose fitting on back of uim broke?
Results 1 to 13 of 13
  1. #1 vacuum hose fitting on back of uim broke?
    Sep 2015
    Lansing, Michigan
    02 gp series 2. The vacuum hose fitting that attaches to the uim on back side. There are 2 hoses attached to it. The part that the skinny hose attaches to broke off the adapter.
    Auto zone doesnt know what to search. What is it called? it came with my uim kit from dorman. Can I fix this without going to the jy? It's bitter cold in michigan right now lol. What does the skinny hose run to?
  2. #2 Re: vacuum hose fitting on back of uim broke?
    if you got a plastic intake that port comes off, can be swapped out with a junk yard one. no idea if it can be bought on its own. maybe a dealer if it comes to it, but its part of the intake set im sure.
  3. #3 Re: vacuum hose fitting on back of uim broke?
    Sep 2015
    Lansing, Michigan
    yeah i replaced my stock uim last year with a dorman one. it's the black plastic one. kit came with all the gaskets, and fittings, etc. i wonder if i saved parts off the old uim i'd have to look in my garage lol.
    so is this most likely a jy part? can anything be cobbled together from vacuum fittings from auto zone?
  4. #4 Re: vacuum hose fitting on back of uim broke?
    if you got the old one still take a look at it, it slides up and off iirc.
  5. #5 Re: vacuum hose fitting on back of uim broke?
    found a pic
  6. #6 Re: vacuum hose fitting on back of uim broke?
    Sep 2015
    Lansing, Michigan
    yeah the part that broke is the one that's to the left of that PCV spring. the skinny inlet that the skinny vacuum hose plugs into broke off.
  7. #7 Re: vacuum hose fitting on back of uim broke?
    Sep 2015
    Lansing, Michigan
    i know i threw my old UIM away but I can't remember if I saved the old vacuum fitting or not. i know i threw the PCV plastic part away because it broke.
  8. #8 Re: vacuum hose fitting on back of uim broke?
    if it broke off flush you could drive a wood screw in the hole to stop the vac leak. heater air flow might quit working, cause thats what that vac line does.
    dont think glue will hold. it might last a little while.
  9. #9 Re: vacuum hose fitting on back of uim broke?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I just found mine from before I did my topswap it's a newer one from a dorman UIM.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  10. #10 Re: vacuum hose fitting on back of uim broke?
    Sep 2015
    Lansing, Michigan
    Yeah that is it. I can't find my old one must've threw it away. Is there any specific name for it? Auto parts stores don't sell it? I dread going to jy in this weather lol. Was there last Tuesday.
    Broke it off replacing my uim gasket for the 2nd time.
  11. #11 Re: vacuum hose fitting on back of uim broke?
    Jul 2015
    Jamestown, NY
    I don't think you can buy it separate it comes with the UIM. Do you need UIM gaskets? I have 2 new ones.
  12. #12 Re: vacuum hose fitting on back of uim broke?
    Jul 2015
    Jamestown, NY
    I was implying I'd sell you this one if you didn't catch that? Lol I just went and dug through my parts pile for it.
  13. #13 Re: vacuum hose fitting on back of uim broke?
    GrandPrix Junkie
    St. Louis
    Might check the HELP! section at you local parts stores. Pretty sure I've seen it there before. If not, then just grab the one Tonkin has. F the cold.
  1. Oxgen sensors,pulleys, heater hose fitting
    By Supercharged GTX in forum For Sale - Parts
    Last Post: 07-27-2014, 05:22 PM
  2. WTB: MAP sensor vacuum hose or vacuum tees
    By Dschroeter63 in forum Wanted To Buy - Parts
    Last Post: 09-22-2013, 02:23 PM
  3. Heater hose adapter fitting part #'s and information.....
    By copgtp in forum How To Write-Ups/Tech Tips
    Last Post: 11-27-2012, 08:53 AM
  4. Car overheating missing heater hose fitting
    By JulieC in forum General Grand Prix Discussion
    Last Post: 10-01-2012, 08:24 PM
  5. Heater hose bypass fitting.
    By Peirce1970 in forum General Tech Discussion
    Last Post: 01-30-2012, 03:35 PM
