Thread: Anyone ever have a fuel injector connector that sticks?
Results 1 to 3 of 3
  1. #1 Anyone ever have a fuel injector connector that sticks?
    Sep 2015
    Lansing, Michigan
    I think it's cylinder 6 that is sticking. I pulled the blue clip up and pressed the tab with a pick. The connector will not disconnect. I removed this connector a week ago and it was sticking. Somehow I moved it a certain way and it disconnected.
  2. #2 Re: Anyone ever have a fuel injector connector that sticks?
    if the plug has a metal bar across it, push the bar in and lift the plug off.
  3. #3 Re: Anyone ever have a fuel injector connector that sticks?
    Quincy, Mass
    Try to wiggle as you pull up on it, they can be a pain. Use your thumb on the tab.
    No more GP 04 Impala SS Indy:
  1. Fuel Rail Line Connector Leak
    By thekidinbuff in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2015, 06:47 PM
  2. Fuel pump resistor jumper connector? (Caspers kit)
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 06-07-2014, 08:46 AM
  3. WTB 42.5lb fuel injector
    By jlgp2007nc in forum Wanted To Buy - Parts
    Last Post: 06-05-2014, 02:06 PM
  4. Need Info, Fuel Line Connector
    By PlayingMechanic in forum General Tech Discussion
    Last Post: 02-03-2012, 12:13 PM
  5. Fuel pump connector diagram
    By Justinzoso in forum General Tech Discussion
    Last Post: 08-31-2010, 09:42 AM
