Thread: resetting SERVICE ENGINE SOON light
Results 1 to 11 of 11
  1. #1 resetting SERVICE ENGINE SOON light
    Feb 2016
    North Carolina
    I have a 2002 GP with V6 naturally aspirated engine ,is there an easy way to reset the SERVICE ENGINE SOON light. I do not have the code reader to do this ,will disconnecting battery reset light ,how long should I leave the battery disconnected ?
    I am sure the light came on due to a loose gas filler cap.
    Al
  2. #2 Re: resetting SERVICE ENGINE SOON light
    if it was a loose cap and you made it tight the code would go out on its own.
    being you have no scanner you have no idea what code you have, so get it scanned. follow the code to repair it.
    to reset the pcm un hook the battery for 30 minutes or over night. but the light will come back if you have not fixed anything.
  3. #3 Re: resetting SERVICE ENGINE SOON light
    SWPA
    30 minutes isn't necessary. 30 seconds will do it. Hell 10 seconds will do it, but as mentioned go get it read so you know what you are dealing with. You could also buy a cheap reader on amazon or eBay.
  4. #4 Re: resetting SERVICE ENGINE SOON light
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    [QUOTE=stealthee;144984} You could also buy a cheap reader on amazon or eBay.[/QUOTE]
    Or Harbor Freight Tools, if you have one nearby. 700 stores nationwide.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  5. #5 Re: resetting SERVICE ENGINE SOON light
    GTP Level Member
    Jun 2016
    Cleveland ohio
    take it to one of the autoparts stores that will pull the code. Autozone and Advanced auto do it for free.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  6. #6 Re: resetting SERVICE ENGINE SOON light
    SWPA
    There are ones even cheaper than what Harbor Freight sells...
  7. #7 Re: resetting SERVICE ENGINE SOON light
    i got one for under 20 shipped of ebay, its worked in every car ive used it on.
  8. #8 Re: resetting SERVICE ENGINE SOON light
    Nov 2011
    NY
    No idea what the light is and you want to turn the light off. Mask the problem, then wonder why engine seized or your brakes failed, etc. Just get a scan, or waste a little time and have a repair shop diagnose the problem, there's nothing that says you must then do the repairs... You can then take the car home and fix the problem yourself if you're handy. Not sure what you're asking... It's different when someone knows what the code is, ie, evap, and wants to just turn it off...
    Good Luck!
  9. #9 Re: resetting SERVICE ENGINE SOON light ( UPDATE )
    Feb 2016
    North Carolina
    UPDATE ...
    I had reset the light last month ,my error came back again ,about 1 month later, so I got a code reader.
    The code is P0442 Evaporative Emission Leak Detected ( small leak )
    again I was able to reset.
    where should I look , can it be the gas cap I do see small areas of broken rubber around its seal on cap ?
    I had this same error code about 3 years ago ,checked out by a shop and they felt it was just a loose gas cap ... hasn't come back since ,but has reappeared in the last month or so twice now.
    Al
  10. #10 Re: resetting SERVICE ENGINE SOON light
    id start with a new gas cap. check for a busted vac line off the tb to the evap solenoid too. those are the easy things to check. after that a smoke test would be a huge help.
  11. #11 Re: resetting SERVICE ENGINE SOON light
    GT Level Member mguzzo's Avatar
    Buffalo NY
    P0442 "small leak" is from a hole less than 0.040", is usually due to leaky gas cap, or in my case the filler neck to the tank was rusted and had a pinhole. needed a smoke test to find it.
    P0440 is "large leak" > 0.040", broken line, gas cap totally off, etc.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  1. Service engine light
    By Hpiracr28 in forum General Grand Prix Discussion
    Last Post: 08-04-2016, 10:38 PM
  2. service engine light
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 09-10-2015, 07:51 PM
  3. Resetting Check Engine Light
    By debyreon in forum Introductions/Noob Questions
    Last Post: 06-11-2011, 12:43 PM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
