Re: Cam install, metal dust in oil!?!?
I found out the assembly lube I used and most assembly lubes use graphite. Did a test with some oil and a pinch of lube sure enough turned metalic. Now this doesn't account for the few bigger peices unless it was foreign or old head gasket. Just going to hope for the best and stay out of high rpm and boost until I'm sure. What rpms do you guys set your idle at with cams? I set mine at 900 but want to preserve the damper as long as possible since I'm running the dampener killer 90#ers.
sounds good then. mystery solved.
drive it.. you'll know quick enough if something is bad.
Debris gets everywhere when scraping and cleaning. That's why we all say run it and dump it.
True...I gave it a couple min of run time..and dump
Appreciate the help, no better feeling than having to do everything all over again.
Cam guys, what rpm did you set your idle at?
had mine around 800..maybe 1000. It's more of what feels/runs right
If you want to have best of both worlds, set it low but safe in gear and lower in N only
so when you want to hear your bumpstick, shift it to N ;)
It runs ok at 900 but want to save dampener. Bumpstick, I love it. Anyone running 90#ers?
dude..I have an audi. No idea what springs she came with. Fast though
I ran 90# springs with an xp for awhile. Iirc, I just left idle at stock....maybe raised it 50rpm.
What did your dampener look like?
Well, after 30k miles, I swapped to 130# springs. Then, after 20k miles on those, I pulled the chain and dampner....very little wear. Probably equivalent to a stock motor with 150k on it.
94GrandPrixSE
700 rpm
Cause the sound is half the fun
I don't have a dampener.
When I did it was with s1x and 105s. It looked fine when I took it out
Stock dampener. 90 Springs. VS cam. I idle at 775 rpm. Sounds and idles like stock. On a rebuild I changed oil after first startup, 100 miles, 500 miles, then normal oil changes. Probably overkill but oil is cheap and wanted to make sure any contaminates, ie leftover gasket, assembly lube, dust, dirt, antifreeze, etc, got flushed out.
Re: Cam install, so many misfires TCC wont lock
Put some miles on the cam, metallic in oil seems to have faded away. Car sounds great, and scoots right down the road but im chasing this random misfire that I believe is causing my TCC not to lock.
Im using AL103's gaped at .52. From my research im using the right temp plugs and gap. My coils were fine before the cam install (no misfires). I did notice a small crack where the bolt to the coil bracket but cant imagine that would cause my issue. Cylinders 6 and 4 misfire much more than the others.
Any advice??
swap that coil. the crack could be the issue.
Will do scotty, is MSD as bad as ive heard?
those plugs only last like 3000-5000 miles, and that gap is bigger than it needs to be, I gap mine to .35.
