Hello folks,
I recently bought my mom a 1995 Pontiac Grand Prix. I gave $300.00 dollars for it. The original owners of the car ran it low on fluid and burned the third gear clutch pack up. I have installed another trans-axle in it and everything is doing great on it. The body is in great shape and the interior is clean. Now I have to work on some minor issues with it. All of the windows are electric and work however, the driver side window does not. Here's what I have checked and done:
1. I have changed the window switches out with another set on the driver side (no dice)
2. I have gotten another regulator from the salvage yard and plugged it in outside the door to see if that was the issue (no dice)
3. I have checked the voltage on the passenger window, it takes 9.6 volts for the motor to move the regulator up and down according to my test. when I checked the driver-side motor plug, it gets 9.6 volts when the switch is pressed. It has the auto down on the driver side. when i was checking the volts I had noticed that the relay for the auto down was clicking like it was suppose to when the switch was pressed.
I need to know where to go from here. If I need to check something different, or recheck something let me know.
Thanks,
littlekatfish2003
