Thread: New (to me comp g) lots of problems
Results 1 to 9 of 9
  1. #1 New (to me comp g) lots of problems
    SE Level Member 04whitegtp's Avatar
    May 2014
    Lansing Michigan
    First off, got this car with a blow motor, and lower mile trans. Car has all the service lights ( stability, traction, abs, brake) and when trying to check codes with the tech 2 i cannot connect to the chassis computer. Any ideas where to start?
    Sent from my SM-N920P using Tapatalk
    Using Tapatalk
  2. #2 Re: New (to me comp g) lots of problems
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Have you checked all the fuses? Also make sure the battery has good power and all the grounds are good. Be sure the ECM is plugged in correctly or making a good connection.
    I'm not that great at electrical, I'm sure soon enough one of the pros will help you out.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  3. #3 Re: New (to me comp g) lots of problems
    power port fuse powers the obd2 port.
  4. #4 Re: New (to me comp g) lots of problems
    May 2014
    Lansing Michigan
    I can connect to the powertrain and body information, but when i go to chassis it says to check connection. Where should I start looking connection wise?
    Using Tapatalk
  5. #5 Re: New (to me comp g) lots of problems
    might be a bad ebcm if it cant connect to only the abs. but reads everything else.
  6. #6 Re: New (to me comp g) lots of problems
    May 2014
    Lansing Michigan
    How could I troubleshoot a bad ebcm?
    Using Tapatalk
  7. #7 Re: New (to me comp g) lots of problems
    iirc not connecting is the troubleshooting. you can always unplug all its plugs clean them and re install em and try to scan it again. or just cleaning the plugs can make the lights go off on its own. while there look for damaged wires.
  8. #8 Re: New (to me comp g) lots of problems
    May 2014
    Lansing Michigan
    Are the ebcm's from comp g's special? Or would one work from another model?
    Using Tapatalk
  9. #9 Re: New (to me comp g) lots of problems
    should be all the same. for your year of course. theres a part # on them. best to get one that is the same as yours.
  1. *Price Drop* 2004 Comp G "The Panda" Low, big HP, lots of stop!
    By WhiteLightningGTP in forum For Sale - Vehicles
    Last Post: 10-13-2015, 11:32 PM
  2. New guy with LOTS of problems
    By isimon in forum General Tech Discussion
    Last Post: 10-24-2012, 12:11 AM
  3. i got lots of problems!
    By 96grandprixse in forum General Tech Discussion
    Last Post: 03-27-2010, 11:54 PM
  4. 04 GTP with lots of problems, Need help
    By what9612 in forum General Tech Discussion
    Last Post: 09-16-2009, 06:56 PM
  5. Lots of problems with GP on this page
    By RageGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2009, 12:14 PM
