Thread: P0446- Cant fuel at all and some random issues.
Results 1 to 20 of 20
  1. #1 P0446- Cant fuel at all and some random issues.
    Sep 2016
    PA
    Hey guys,
    Ok so my dad owns a 04 Grand Prix GTP with about 160K. I have some issues with the car that I'm doing my best to fix with out bringing it to the dealer.
    P0446- I think this has to do with some circuit but I honesty don't know where to start. Let me start by saying the car was just in the shop for the reason of my dad cant fuel his car with out it stopping every 10 seconds or so. We brought it in to the shop not a dealer. They replaced the Canister in the rear quarter and also replaced a sensor on the fuel pump, Pressure sensor I think? they also cleaned out the hoses on top of the tank the tech said. There at a loss and don't know what's wrong. They also put a camera down the filler neck and didn't see anything..They refunded us the money back which was nice. So the issue still remains but now the gas shoots out the filler neck a couple seconds after the pump stops, before it would just stop now the gas wont stay down, it never did this before..I think I replaced the Purge valve under the hood awhile ago at some point maybe that went bad? Any help on this would be great, do I have to drop the tank again? We have some other issues but we need to fix this first.
    Thanks fellas.
  2. #2 Re: P0446- Cant fuel at all and some random issues.
    https://www.obd-codes.com/p0446 they list a bad pcm as a possible issue. if the shop tested the wires to the vent solenoid and they are ok and the new solenoid as well with a canister.
    did they say if the canister was full of gas or not?
  3. #3 Re: P0446- Cant fuel at all and some random issues.
    Sep 2016
    PA
    Hey Scotty,
    I hope it's not the PCM wounldnt anything else go wrong if the PCM went bad?
    And no they didn't check the wires..Good techs I guess...No there was no gas in it. Right now there a brand new install as well.
  4. #4 Re: P0446- Cant fuel at all and some random issues.
    take a look at the wires to the purge solenoid for any damage.
    pcm can go bad and only effect one item.
  5. #5 Re: P0446- Cant fuel at all and some random issues.
    Sep 2016
    PA
    Ok, That's under the hood correct? I'm just looking for Visual damage correct?
  6. #6 Re: P0446- Cant fuel at all and some random issues.
    theres two solenoids, on a top the canister, and one on the engine. canister one is a vent solenoid, the engine one is purge solenoid. i think the code listed is the canister solenoid. being you have a adding fuel issue.
  7. #7 Re: P0446- Cant fuel at all and some random issues.
    Sep 2016
    PA
    Ok got ya, Would that cause it to shoot back out of the filler neck aswell? Before it was just stopping every couple seconds now when coming back from the shop it does this.
  8. #8 Re: P0446- Cant fuel at all and some random issues.
    when gas wont pump, or shoots back out, thats canister issue or that solenoid most of the time, or a busted wire or hose to it.
  9. #9 Re: P0446- Cant fuel at all and some random issues.
    Sep 2016
    PA
    Ahh ok ok. I remember changing that out one time and I had to buy a pigtail for it, GM had a recall on that or something I forgot but it was like 20-30$ for the harness. Ill check it out, if the wires appear to be ok" whats next?
  10. #10 Re: P0446- Cant fuel at all and some random issues.
    not really sure other making sure the vent lines are not clogged up. your year might have one running up the filler neck too.
  11. #11 Re: P0446- Cant fuel at all and some random issues.
    Sep 2016
    PA
    So I'm just looking for Damaged wires. Nothing with a multi meter or anything right? That code is for a electrical problem it seems...Ugh this sucks lol...How would I know if the line is clogged? or I should say how to check?
  12. #12 Re: P0446- Cant fuel at all and some random issues.
    take what you can off and blow air through them. wires your looking for cracks or bare wires showing.
  13. #13 Re: P0446- Cant fuel at all and some random issues.
    Sep 2016
    PA
    Sorry for the late reply.
    Ok, I took of the Canister and it appears they didn't change it but I tested it with a battery and you can see it closing and opening. My question now is it appeared open so wouldn't it have filled with gas ok?
    Secondly I hook up the canister sensor and then the turn the car on to accessory mode not fully turning the car on and I'm not getting a reading off the connector from the car to connect to the canister, does that make sense? I'm alittle lost here lol
  14. #14 Re: P0446- Cant fuel at all and some random issues.
    car might have to be running for that test.
    did the canister have gas in side it? it should be dry.
  15. #15 Re: P0446- Cant fuel at all and some random issues.
    Sep 2016
    PA
    Nah it was Bone dry. I'm not to savy when it comes to multimeters but I think the plug came back with a reading of 11 something volts car off or on. Hopefully I tested it right lol. I didn't see any bare wires or anything. So I'm not really sure.
    Does gas pass through there or something for that to happen?
  16. #16 Re: P0446- Cant fuel at all and some random issues.
    i think its just to vent the tank as it fills up or as it gets lower due to use.
    im no good with a dmm either. im no help there.
  17. #17 Re: P0446- Cant fuel at all and some random issues.
    Sep 2016
    PA
    Yeah, could it be he Purge valve not working right? As I read more on the code it's says it trips when it senses to much pressure or not enough pressure? Maybe something blocking it? I may have to drop the tank?
  18. #18 Re: P0446- Cant fuel at all and some random issues.
    Sep 2016
    PA
    Anyone else can shed some light on this?
  19. #19 Re: P0446- Cant fuel at all and some random issues.
    Quincy, Mass
    Have you tried filling it slowly? My wife's 06 would did fill up and stop thing a lot and I would have to let it vent with the gas cap off and the nozzle in enough to open the flap and then I could fill it probably 2/3 of the way but have to go slow. It stopped doing it but I don't know why, never got any codes.
    Your canister you say works because it opens and closes. But it sounds like it's not doing it while you fill up so whatever tells that to open or close isn't doing it's job.
    No more GP 04 Impala SS Indy:
  20. #20 Re: P0446- Cant fuel at all and some random issues.
    Sep 2016
    PA
    Well not yet, we are a little scared because the last time the gas shot back out of the car and gas got everywhere, but yes the plan is to try it slow but it shouldn't be doing this ya know and it needs to get fixed.
    Yeah the canister works when I apply power but like you said something isn't happening but from what I read that code will set off if it senses blockage or if not enough pressure I think...P0446 is the code...ugh I'm kind of stuck here..im not sure if I need to drop the tank or not. I'm wondering if the big charcoal canister down above the gas tank is messed up possible, maybe? Or if another part is causeing somthing.
  1. Random multiple misfires issues
    By Austins01GP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2016, 06:34 PM
  2. Solution to random electrical issues on '02 GP?
    By NotEnoughGPs in forum General Tech Discussion
    Last Post: 02-04-2015, 05:30 PM
  3. 98 GT random issues.
    By 1996grandprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-10-2014, 12:22 PM
  4. Random electrical issues.
    By WolvesSoulZ in forum General Tech Discussion
    Last Post: 05-07-2014, 12:27 PM
  5. P0446 Showing Up After Airtex Fuel Pump Install
    By talladam in forum General Tech Discussion
    Last Post: 07-20-2012, 02:24 PM
