Thread: power steering pump
Results 1 to 3 of 3
  1. #1 power steering pump
    Akron, Ohio
    2006 gp GT, lots of miles
    So had the teering rack replaced a couple years ago and still had a low speed grind, got a new pump (autozone), still had the grind, replaced pump - worked for a while - then low speed grind came back. Lived with it. Then the steering rack went again. All was good for 7 days and the low speed grind came back. Mech - who I trust - said pump is bad - it is letting air in the system - which I guess makes sense because after service went away for a while.
    So my question is
    1 - get another form autozone - free lifetime warranty
    2 - get used OEM one - $60
    3 - get new OEM - $160
    I like the ides of free, and I can change the pump in less than an hour, but I am sick and tired of doing it.
    What would you do?
  2. #2 Re: power steering pump
    St. Louis
    Well, how many times do you want to screw with it? If the answer is one more time then I'd get the Delco one and be done with it. My steering is too important to cheap out on and having a noisy car is just a pet peeve of mine, lol..
  3. #3 Re: power steering pump
    jack both front wheels off the ground, then turn the wheels lock to lock 15 times, engine off, this will bleed the rack of any air.
    a pump cant let air in the system. mech you trust is silly.
  1. Power Steering Pump Going Bye Bye?
    By burgundybullet in forum General Tech Discussion
    Last Post: 02-28-2013, 11:15 AM
  2. Power Steering Pump On Its Way Out
    By Danarchy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2012, 01:28 PM
  3. 99 GT power steering pump
    By BmoreDrew in forum General Tech Discussion
    Last Post: 04-10-2011, 11:13 PM
  4. Need New Power Steering Pump?
    By brandonl2000 in forum General Tech Discussion
    Last Post: 12-05-2010, 01:59 PM
  5. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
