Thread: Push to connect fittings
Results 1 to 5 of 5
  1. #1 Push to connect fittings
    Quincy, Mass
    I want to use these, I've seen PRJ use them in his builds and I like the way they look and work. My questions is how do I get them onto the connections at the lim, fpr, BBV, and MAP sensors? Do they just push right on or is there another adapter for them?
    No more GP 04 Impala SS Indy:
  2. #2 Re: Push to connect fittings
    hangover park IL
    Lim: yank nipple with pliers n drill/tap to 1/8th npt
    Most aftermarket fuel pressure regulators already have 8th inch npt threads.
    The rest would probably use a short piece of silicon hose as the coupler.
    If you wanted to carefully modify the map sensor and boost bypass valve nipples to use a push connect to ordinary compression you would be able to read them up but doing that on to plastic nipples of the Boost bypass valve would probably lead to very likely snapping off the nipple
    ~James~ Psychotic Gearhead
  3. #3 Re: Push to connect fittings
    Quincy, Mass
    Ok that's what I was thinking. Stock fpr and fuel rails though.
  4. #4 Re: Push to connect fittings
    hangover park IL
    stock lines fer stock jank, just stick to the WG/BOV/boost controller for youjr push connect stuff
    you have single solenoid or dual sol boost controller?
  5. #5 Re: Push to connect fittings
    Quincy, Mass
    Supercharged not turbo anymore.
