Thread: 150k Mileage
Results 1 to 4 of 4
  1. #1 150k Mileage
    Mar 2016
    Bridgeport
    Hi guys, I recently just passed the 150k mark with my grand prix gxp. I was just curious if there were any issues I should be on the look for with the higher mileage. The tranny shifts fine, I bought the car at 142k about 7 months ago and haven't had any issues with the car, other than changing brakes no work has been done. Any things you guys could suggest would be greatly appreciated!
  2. #2 Re: 150k Mileage
    Coolant change if it's never been done.
    Spark plugs if you have no history on them.
    Clean the MAF sensor because it's a good idea to do that every now and then.
    Olny major set backs can be the transmission or the DoD/AFM system having problems someday. I've seen many Dod/AFM engines run for 200k miles with no issues but some with 50k and they get the common failed lifter. It's the luck of the draw there.
  3. #3 Re: 150k Mileage
    Tranny cooler.
    ASAP.
  4. #4 Re: 150k Mileage
    GTP Level Member
    Aug 2012
    st louis park, MN
    You may want to inspect the transmission fluid for color and smell. If it is dark or smells burnt read up on related threads on this forum before replacing the fluid.
    This thread might help you identify some other maintenance items you can look into: http://www.grandprixforums.net/threa...00-Powered-Car!!
    Cheers,
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  1. Used 04 GP 150K acceleration problems
    By GPfoSHEEZY in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-05-2014, 09:09 AM
  2. 2002 GP GTP 150k miles
    By SpeedJunkie in forum General Grand Prix Discussion
    Last Post: 05-05-2012, 11:21 AM
  3. Daily driver suspension for 150K car
    By geoffwilde in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2011, 07:28 PM
  4. Driving 99 GT across country 150k mi - Preventative maint?
    By BmoreDrew in forum General Tech Discussion
    Last Post: 04-06-2010, 01:05 PM
  5. 150K suspension refresh
    By Smokin2000gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 08:14 PM
