Thread: Raspy hiss from dash/center-console when Accelerating
Results 1 to 19 of 19
  1. #1 Raspy hiss from dash/center-console when Accelerating
    GTP Level Member
    Aug 2012
    st louis park, MN
    Hi All,
    I'm brand new to the forums and have done a little searching without luck (I didn't try too hard.)
    I have a 2008 grand prix with almost 80k miles and no mods. Under hard acceleration I'm getting a raspy hissing noise that follows the RPMs of the engine. It seems to be coming from behind the a/c control area (in the dash somewhere) or the front portion of the center console. When the engine is cool, the noise is more of a raspy squawk/squeal. It is louder when the car is not warmed up and gradually changes to a quite raspy hiss at the car warms up. It verges on barely audible once the car is warm, like when I swung by the dealer (who told me not to worry about it .
    The car is running smoothly with no dummy lights and the tranny is shifting as smooth as I ever remember. I haven't noticed any power loss, just the unusual noise.
    It makes the noise with AND without the A/C fan on.
    Any help or ideas would be appreciated!
  2. #2 Re: Raspy hiss from dash/center-console when Accelerating
    could be a broken vac line to the vent direction diaphragm. you should have 2 of them on on each side of the dash center console area.
    does your defrost, vent, and floor vents all change and operate like they are supposed too?
  3. #3 Re: Raspy hiss from dash/center-console when Accelerating
    GTP Level Member
    Aug 2012
    st louis park, MN
    I believe they are all working fine. I will double check that they are all working properly.
    Can I visually check for leaks or damage without taking the dash apart? How would I go about checking?
    Thanks for your help!
  4. #4 Re: Raspy hiss from dash/center-console when Accelerating
    this write up is for the blend door actuators, but the diaphragms are in the pic, same deal getting to them.
    http://www.grandprixforums.net/blend...ent-21941.html
  5. #5 Re: Raspy hiss from dash/center-console when Accelerating
    GTP Level Member
    Aug 2012
    st louis park, MN
    I'm going to take some things apart this weekend and see what I can find. Where in the pictures are the diaphrams and how would I check them, any ideas?
    The issue is more common now but I only notice it when I punch it on the highway. Through some other browsing I thought it may have been air in my cooling system since I've heard the glug-glug-glug watery noise behind my dash in the past. I bled the system as instructed and found no improvement to the current noise I'm having.
    Does anyone have other ideas on my issue? Any chance it could be belt squeel, or an exhaust leak? My gut feeling is it's related to fluid or air flow.
    Thanks gents.
  6. #6 Re: Raspy hiss from dash/center-console when Accelerating
    the glug glug, or gurgling sounds could be air in your heater core. take both hoses off the back of the alt, then flush with a garden hose, after you flush it, fill both hoses up, and quickly get them back on the engine.
    if your heat feels weak, this would defiantly be your problem.
    if you take the glove box out, look to the left, but up by the front of the dash, you cant miss the vacuum actuator. it has a vac hose to its round, about 3 inches across. its in the pic with the actuators for the blend doors in that link up a few posts.
  7. #7 Re: Raspy hiss from dash/center-console when Accelerating
    GTP Level Member
    Aug 2012
    st louis park, MN
    Scotty,
    Before I had read your post I read a couple other places that I could bleed air from the heater core (and the whole system) if everything was warmed up and the heat blasting on high by simply bleeding from the bleeder screw.
    I did this and it seemed much hotter the next day. Then a few days later it doesn't seem quite as hot anymore. Can I successfully remove all the air with my method OR is your's a better approach?
    In your description you said remove the hoses from the alt, you mean alternator? I wouldn't think coolant lines would run to that but I'm new to this. So "flushing" with the garden hose does what - forces air out of the heater core and then with lines refilled the system should be air free?
    Thanks for your help.
  8. #8 Re: Raspy hiss from dash/center-console when Accelerating
    alt = alternator, and i should have said bracket, its under the alt. take them two hoses off, flush either one with a hose.
    when air gets trapped in the heater core, its hard to get it out by just using the bleeder screw on the t stat housing. flushing it, and filling the hoses up, and putting them back on will work best.
  9. #9 Re: Raspy hiss from dash/center-console when Accelerating
    GTP Level Member
    Aug 2012
    st louis park, MN
    Scotty, I see what you are talking about with the hoses and heater core. My first concern is now that I am in MN winter, would I be at risk of freezing my block by replacing the amount of coolant in the heater core and attached hoses with pure water vs 50/50 mix?
    Second, when you say "flush, refill hoses, and get back on engine quickly" are you just getting the fact that, after flushing the heater core, I don't want to let water drain out of the hoses because it will just cause more air to get back in the system?
    Thanks man.
  10. #10 Re: Raspy hiss from dash/center-console when Accelerating
    the core and hose hold maybe a 1/2 gallon, if your coolant is old, you may want to flush it and add new coolant altogether. most of the time it will be ok.
    and yes, try to keep the hoses full to avoid any air getting back in, some will spill out, just try to minimize it.
    they also sell antifreeze testers, cost like 5 or 6 bucks, it will tell you how cold your coolant is good for.
  11. #11 Re: Raspy hiss from dash/center-console when Accelerating
    GTP Level Member
    Aug 2012
    st louis park, MN
    Would it maybe be worth paying someone to flush the system? Would they for sure get all the air/crud out and then I would have good coolant for sure?
    I'm leaning that way.
  12. #12 Re: Raspy hiss from dash/center-console when Accelerating
    you can flush your own coolant for under 20 bucks, the cost of a new gasket for the t stat and a gallon of straight coolant.
    remove the t stat, then put the housing back on with out the thermostat installed. then take the hose off the upper rad. leaving it on the engine side,( the t stat housing) then push the upper hose down to the ground, open the rad cap, have a garden hose ready.
    start the car, with the hose on and in the rad cap, idle the car till clear water comes out of the upper hose.
    once you have clean clear water, turn the hose off run the car till water stops coming out the upper hose. then turn the car off.
    now put the new gasket in, the t stat back in, the upper hose back on, and dump 1 gallon of straight coolant, not the 50/50 stuff. start the car, add water as needed, bleed the system . top off, done.
  13. #13 Re: Raspy hiss from dash/center-console when Accelerating
    GTP Level Member
    Aug 2012
    st louis park, MN
    I put in a new thermostat and bled from the bleeder screw again and things seem to be working well now - once temps reach sub 0degF it may be another story. I still think a system flush is in order once spring rolls around.
    How much waste fluid will I end up having for your flushing procedure listed above. A couple gallons or like 20 gallons? Thanks.
  14. #14 Re: Raspy hiss from dash/center-console when Accelerating
    waste coolant? none at all is wasted.
  15. #15 Re: Raspy hiss from dash/center-console when Accelerating
    GTP Level Member
    Aug 2012
    st louis park, MN
    If I do a system flush, that fluid coming out of the upper hose has to go somewhere. Just curious how many buckets to have to catch all the old coolant and contaminated water.
  16. #16 Re: Raspy hiss from dash/center-console when Accelerating
    you want the old coolant to come out, all of it, run the car till clear water comes out, then take the hose out of the radiator, turn the car off when water stops coming out the upper hose.
    you then put it back together and add 1 full gallon of new coolant to the rad, then fill it with water, and then bleed the air out. and thats it.
    you can have 2 5 gallon buckets handy to catch the old coolant, you'll need the car up on ramp or jack stands to get it under there. or a large storage bin.
    if you just let it dump on the ground wash it down good animals like to drink it and it can kill then, and it will stain your driveway to some degree for a while, water washes is away tho.
    the engine and rad, take maybe 3 gallons or a bit more to fill, so not a whole lot of coolant will be coming out.
  17. #17 Re: Raspy hiss from dash/center-console when Accelerating
    May 2016
    Lincoln, Nebr
    I also have an 08 GP base and had this same issue with the hissing sound. I thought it was a pulley for the longest time cuz it make noise parallel with RPMs around 3,000 and up.
    Anyway, I developed a heater core leak and replaced that and (knock on wood) I don't hear the noise anymore. Noticed the hissing sound around 120,000 mi. and heater core gave out around 128,000 mi.
    This was all very strange to me because prior to all both of these issues occurring, I did my normal scheduled maintenance coolant flush (prestone and 2x w/ distilled) and then 3 months after the flush I ended up replacing the tensioner - added more new coolant, and then 2-3 months after that I replaced the water pump (thought it was the hissing - not the case), so put in more new coolant. So this coolant system had been getting a lot of attention and wasn't neglected at all. And I always bleed and use the Lisle spill free funnel to burp the system.
  18. #18 Re: Raspy hiss from dash/center-console when Accelerating
    GTP Level Member
    Aug 2012
    st louis park, MN
    So it ended up being the heater core? I'm impressed you found this thread and that another owner experienced the same issue, haha.
    I think mine has stopped doing it quite a while ago (or I stopped caring/noticing) and I'm at 136,000 right now.
    How was replacing the heater core? I hear it's a pain!
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  19. #19 Re: Raspy hiss from dash/center-console when Accelerating
    May 2016
    Lincoln, Nebr
    I'm about 4-5 days into my new heater core and I don't hear the noise anymore (again...knock on wood), so only time will tell.
    I'm guessing I might have had a slight blockage and the hissing noise was faster moving coolant liquid rushing past the blockage upon acceleration. Because obviously the water pump rotates faster when you accelerate so fluid moves quicker. Again, I just don't know for sure, cuz my heat always worked great and my coolant is bright orange from regular servicing, so my instinct tells me a blockage was highly unlikely.
    But the noise seemed really sporadic to begin with. Some days it was clock work - 3,000 RMPs and higher on every acceleration. Other days it was faint and I couldn't hear it until 4,000 RMPs (obviously a hard acceleration). I even bought a engine stethoscope and was listening to different pulleys because I thought, for sure, it was a pulley.
    I think I cracked my heater core because I had AC running to both upper and lower vents, let me explain. Normally, I just run AC to upper vents on a daily basis in summer. I went on a 6 hour road trip, so for the sake of comfort, I had AC running to both the whole time. Well my GP (idk about everybody else's) doesn't not have a Heater Control Valve, so AC is always flowing through the Heater Core even in the summer. A heater control valve will allow the cooling system to bypass the HC when car heat is not needed (aka summer). But for in my case, if the AC is on, air is never blown over this HC (to produce warm air), so you never know the difference, although the floor air vents passes right next to the HC cover. So I speculate that the constant cold air next to my HC for such a long period of time gave it a stress fracture. If you've never seen a stress fracture, put boiling water in a glass cup, pour it out and then put in cold water, it will crack the cup in half.
    Or maybe I'm over analyzing it and the HC was just old and started leaking.
    Anyway, there's a really nice thread on here for heater cores I used: http://www.grandprixforums.net/threa...61#post1444261
    It wasn't the most difficult job, more so challenging because of the location. I definitely wouldn't want to do it again, my back hurt for a few days.
  1. center console
    By kjohnson in forum Visual/Body Modifications
    Last Post: 12-06-2009, 06:51 PM
  2. center console
    By flash527 in forum Visual/Body Modifications
    Last Post: 11-18-2009, 02:43 PM
