Thread: no boost!!
Results 1 to 18 of 18
  1. #1 no boost!!
    howell mi
    hello i have a 98 gtp with t.o.g headers borla exhaust with no cats d.h.p comp thrasher cold air and 3.25 pulley and im only getting about 5 psi can anyone help me please
  2. #2 Re: no boost!!
    West Side Michigan
    Well your gonna get talked down to for having a low pulley size of 3.25 without the correct modifications to support that pulley. That may be why your getting low boost.
  3. #3 Re: no boost!!
    Jul 2008
    nj
    check the boost bypass valve electrical connection. If the BBV does not have an electrical connection or if it is bad, you only get about 4-5 lbs boost. I would also look at the vac line at the BBV while you are there.
    edit for spelling
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  4. #4 Re: no boost!!
    howell mi
    I'll check that out thanks alot. Also I have
    a 3.4 pulley would it be better to put that
    on for the mods I have?
  5. #5 Re: no boost!!
    West Side Michigan
    To have a 3.4 you need:
    Headers
    Intake
    Plugs and Wires
    180* Thermostat
    PCM Tune
    I would put that 3.4 on if you don't have the stock one. You need to make sure your car can handle the extra power your giving it by doing these modifications. A 3.25 is way to low of a pulley with where your at with your modifications.
  6. #6 Re: no boost!!
    howell mi
    Ok I'll do that thanks for being so helpfull guys
  7. #7 Re: no boost!!
    Jul 2008
    nj
    No problem, that is why we are here. Do yourself a favor and scan that car with the 2 pulleys. I am in total agreement with nawarkk, that pulley is too small for your setup.
    FOR SALE
  8. #8 Re: no boost!!
    howell mi
    I have a scanner 2.82 kr with the 3.25
    I have another sc so I'm goin to change
    the bbv now
  9. #9 Re: no boost!!
    GTP Level Member
    Nov 2008
    MA
    Quote Originally Posted by jaygtp98 View Post
    the bbv now
    throw the 3.4 pulley on and your car will be faster since your car is pulling timing right now with the 3.2
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  10. #10 Re: no boost!!
    if it has 2.8x* of knock on 5 pounds of boost then youre in for a rude awakening for when you see full boost numbers.
  11. #11 Re: no boost!!
    Oct 2008
    Northern Illinois
    This...I would get that 3.4 on ASAP if you like your shortblock.
  12. #12 Re: no boost!!
    Jul 2008
    nj
    well, problem fixed?
    FOR SALE
  13. #13 Re: no boost!!
    Nov 2009
    Grand haven
    ^^^ x2. I am in the madison heights area welcome to the site.
  14. #14 Re: no boost!!
    howell mi
    nope changed the bbv and still 5 psi im gonna change the pulley this weekend. i also am getting a low freq code for mass air sensor i cleared the code and put a new one on and still says low freq any ideas anyone?
  15. #15 Re: no boost!!
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Almost guaranteed that the problem is the solenoid for the BBV if you're actually getting on only 5 PSI. Unhook the vac line from the solenoid to the actuator, plug it on the solenoid side and leave the actuator open to atmoshpere. You should see full boost.
    Like Bio said, you're going to blow the thing up, though. I don't think I would even test this with the 3.25 still on there.
    2001 Buick Regal LS - Almost Stock
  16. #16 Re: no boost!!
    howell mi
    I'll change it first then try that thanks alot
    for the advice
  17. #17 Re: no boost!!
    howell mi
    Is there anyone in the Howell Brighton
    mi area that has a pulley pulley and can
    help me out
  18. #18 Re: no boost!!
    Largo, Florida, United States
    you can rent one for 35$ from 3800 Performance
    I rented it but im keeping mine and paying the extra 100$ for ownership
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. How much boost?!
    By Mikegotone'02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2010, 01:01 AM
  3. Boost PSI?
    By JoelW98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2010, 02:35 AM
  4. only 4 lbs boost???
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2009, 04:50 PM
  5. More boost?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-25-2008, 12:33 AM
