Thread: looking to do a cam swap but cant decide which cam
Results 1 to 3 of 3
  1. #1 looking to do a cam swap but cant decide which cam
    GT Level Member 99GPGTP's Avatar
    Rome GA
    im looking in to doing a cam swap in the next 6 months and not sure what cam i should go with. i want it to have a choppy idle but be streatable and not kill fuel mileage to much will have pcm retuned for cam at time of swap. here what i have done so far
    fenderwell intake
    speed daddy headers no cat
    180* tstat
    ported exhaust on heads
    3.4 mod pulley have a 3.2 pulley also
    autolite 104 plugs
    zzp 1.0 pcm
    ported m90
    2650 stall converter rebuilt trans
    future plans are moded intake with intercooler, gen5 blower, new rockers and push rods, would like to run mid 11s in the future
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  2. #2 Re: looking to do a cam swap but cant decide which cam
    Pick the XP cam then.
    A canned ZZP tune will not be what you want, it is impossible to predict the needs of the engine with a canned tune on a cammed/ported cylinders heads engine. All they do is load a random set of numbers into their tables and hope it works. A custom tune is pretty much the only way to go with the mods you have planned, you will also need a wideband o2 sensor to monitor fueling.
    Also just know that you will likely be the max range of both the stock MAF sensor and stock injectors with this setup.
  3. #3 Re: looking to do a cam swap but cant decide which cam
    Rome GA
    i have a wideband o2 installed in the down pipe just after the vband clamp on my headers
  1. I cant decide
    By fbm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2014, 11:02 AM
  2. Decide to try out the HD lip on the 04
    By Alix0r in forum Visual/Body Modifications
    Last Post: 11-12-2013, 02:46 PM
  3. income tax cam in/trying to decide if i should top swap or not
    By sLpGPGT in forum General Grand Prix Discussion
    Last Post: 04-16-2013, 01:46 PM
  4. can't decide...
    By canuckgxp in forum Tires & Wheels
    Last Post: 03-26-2012, 07:03 AM
  5. What to decide on....
    By Iron Indian in forum Tires & Wheels
    Last Post: 02-19-2009, 02:09 AM
