Thread: It's not the blend door
Results 1 to 20 of 28
  1. #1 It's not the blend door
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    So my AC blows warmer on the drivers side than the passenger side. It's not hot like the heaters on but the passenger side is COLD and the drivers side is only cooler than the air outside. I changed the blend door yesterday (what a pain in the ass) and it didn't fix the problem. So what else could it be? A vac leak? A few years ago and I had the compressor repaired because it was leaking so it shouldn't be that. I don't know the inner workings of the system enough to have any real guesses.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: It's not the blend door
    your low on freon, fill er up
  3. #3 Re: It's not the blend door
    Check the high and low pressures on the system.
    On some cars if the R134a level is low only the passenger side will blow cold. I know for sure the bonnevilles are this way.
  4. #4 Re: It's not the blend door
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Could just be clogged fins on the core... Buddy had something like that but with his heater, took a can of air to the heater core and blew all the crap out the other side.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  5. #5 Re: It's not the blend door
    Buffalo, NY
    I'll try the freon. I don't think anything is clogged because the heat worked fine this past winter. Could someone explain how to check and refill the freon on these cars? Or post a link to a write up?
  6. #6 Re: It's not the blend door
    buy one of them refill cans with a gauge, read the can.
  7. #7 Re: It's not the blend door
    I just use the hose and buy the cheap little 12oz cans and fill through the low side port.
    The cans with a gauge are kind of pointless because they only tell you low side pressure and really the high side pressure is more important. You'd have to shove alot of freon in the system to max out the low side and do damage.
    Adding 8-12oz should be enough to tell you if it works or not. You can keep the little can on the hose if you don't use it all, just spin the needle down untill it bottoms out.
  8. #8 Re: It's not the blend door
    Buffalo, NY
    Where is the high pressure port? I've found images of the low online but can't find a definitive answer for the high. Near the alternator? And do I have to worry about refilling the high as well or just the low?
  9. #9 Re: It's not the blend door
    You never fill on the high side.
    One port should be on the firewall and the other is like behind the airbox or close to there.
  10. #10 Re: It's not the blend door
    Buffalo, NY
    The one on the firewall is the low right? Other must be high?
  11. #11 Re: It's not the blend door
    Jan 2014
    AR
    Quote Originally Posted by SomeDudeAtHome View Post
    Small one center of firewall is low. Just hook on a large can of A/C Pro w/gauge and you'll be fixed in a few minutes. Read directions. I know everybody already said all that, I am just supporting it. It's very simple, my 99s need it each year. I'm saying get the big can based on experience and your description.
  12. #12 Re: It's not the blend door
    Buffalo
    If the weather holds up , I'm local and have the tools you need
  13. #13 Re: It's not the blend door
    Buffalo, NY
    Alright so I bought an 18oz can at autozone and put the whole thing in. It only brought the pressure up to about the middle of the green section of the gauge. Vents seemed to be blowing cooler though. Thanks for the help everyone
  14. #14 Re: It's not the blend door
    Oct 2014
    Frederick, MD
    I'm needing to do this, my A/C is starting to take longer and longer to get cold... Lol
  15. #15 Re: It's not the blend door
    Buffalo, NY
    Another question. So if I need to put another can in and may have to do this every summer doesn't that mean it's leaking somewhere? Is it cheap to just keep refilling or should I have it looked at?
  16. #16 Re: It's not the blend door
    most of the time if you look over all the lines you'll find a wet oily mess at a connection or where a sensor in in the pipe. find the dirty wet spot, 99% of the time thats your leak.
    they also sell cans with dye in them to find the leak.
  17. #17 Re: It's not the blend door
    Buffalo, NY
    I'll look them over at some point. Does buying the cans with the leak sealer in it mess up the lines? I noticed pretty much all the bottles said they did that but it seems like using something like that could possibly gunk them up.
  18. #18 Re: It's not the blend door
    Pennsylvania, USA
    Before I had access to an A/C machine I tried those leak-stop cans a few times, they never managed to seal anything. I'd just stick with the straight R-134a. I can stand by the A/C dye though, that with a cheap UV light and some tinted glasses are what I use to find leaks.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  19. #19 Re: It's not the blend door
    Buffalo, NY
    Depending on how long this seems to last I might try the UV stuff. I'm hoping it gets me through this summer. Might go out and by another can since this one didn't get me to the top of the green section on the gauge.
  20. #20 Re: It's not the blend door
    Buffalo
    I'd charge it with nitro and listen for the hiss. Replaced the faulty part / almost always the condenser / and pull a vacuum then recharge it
    however you find the leak - just find it. It's stupid to keep re filling it
  1. Blend door
    By BADAZGTP in forum General Tech Discussion
    Last Post: 06-27-2016, 02:25 AM
  2. PreGen AC blend door
    By alan0517 in forum Introductions/Noob Questions
    Last Post: 07-26-2014, 09:16 AM
  3. Blend doo or Blend door actuator?
    By Logan541 in forum General Tech Discussion
    Last Post: 06-10-2014, 02:29 PM
  4. Blend door
    By PrixieGirl69 in forum General Tech Discussion
    Last Post: 05-06-2014, 09:42 PM
  5. Blend Door
    By 98GTPON22s in forum General Tech Discussion
    Last Post: 03-07-2012, 09:50 PM
