Thread: Question
Results 1 to 9 of 9
  1. #1 Question
    May 2012
    Canada , Sarnia
    Im replacing parts on my 04 gp heres what I got and theres a picture I don't know what that bushing is called in the front and there's a link do I need that for the front also and do the rears have that ??
    Front - Control Arms , Inner Tie Rod , Outter Tie Rod , Sway Bar Links , Quick Struts
    Rear - Sway Bar Link , Quick Struts , Bushings ???
    http://www.rockauto.com/en/moreinfo....429703&jsn=417
  2. #2 Re: Question
    Sway bar bushing
    04 Comp G.
  3. #3 Re: Question
    May 2012
    Canada , Sarnia
    Thanks is that the control arm running through that bushing or is that the sway bar I thought there was only one in the rear ?
  4. #4 Re: Question
    That's the swaybar running though it, you can't see the control arm in that picture. There's a swaybar in the front and rear of the vehicle.
    04 Comp G.
  5. #5 Re: Question
    The control arms run from the sub frame to the steering knuckle on the bottom.
  6. #6 Re: Question
    May 2012
    Canada , Sarnia
    ok would you know the size of the stock swaybar going to order the bushings
  7. #7 Re: Question
    If they can look up the vehicle by make and model there should only be one option for the standard sway bar size.
  8. #8 Re: Question
    canal winchester, ohio
    If you get an aftermarket the size can be slightly different. Mine was a PIA to get in on 1 side (I had to remove the tie rod). Stock would go right in.
  9. #9 Re: Question
    May 2012
    Canada , Sarnia
    thanks guys I got the correct ones
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
