Thread: 1996 Grand Prix - KEY STUCK IN IGNITION
Results 1 to 5 of 5
  1. #1 1996 Grand Prix - KEY STUCK IN IGNITION
    Aug 2016
    Northeast
    Hello:
    I have a '96 Grand Prix with the key stuck in the ignition. I've searched / read dozens of posts but they were for '97 and up models with the access port under the column.
    This car doesn't have the oval access port, so there's no way to push/reset the lock cylinder switch.
    Anyone know what might be causing the key to be stuck? Thanks in advance!
  2. #2 Re: 1996 Grand Prix - KEY STUCK IN IGNITION
    is the battery dead?
    could be a busted wire in the console to the shiftier, or the lock its self is messed up, has it been sticky feeling?
  3. #3 Re: 1996 Grand Prix - KEY STUCK IN IGNITION
    Aug 2016
    Northeast
    The battery is fully charged and the key moves freely. I will check the wiring and report back. Thanks.
  4. #4 Re: 1996 Grand Prix - KEY STUCK IN IGNITION
    Apr 2016
    Dalton, GA
    My sons car did that turn it of and off a few times and make sure it is in park all the the way and the key will come out
  5. #5 Re: 1996 Grand Prix - KEY STUCK IN IGNITION
    Aug 2016
    Northeast
    Success! It was the shifter knob. Specifically, there's a rubber cover over the part which you squeeze first before moving the shifter. That rubber cover moved and jammed the guts inside of the knob.
    So, the lever was not being depressed far enough. I moved the rubber cover to the proper position and now the key is easily removed. Thanks again.
  1. 1996 Grand Prix SE temperature gauge stuck on 260 deg
    By keeney12 in forum General Grand Prix Discussion
    Last Post: 01-25-2015, 09:55 AM
  2. Replies: 12
    Last Post: 07-21-2013, 08:40 PM
  3. key stuck in ignition 2002 grand prix
    By bidiheston in forum General Tech Discussion
    Last Post: 01-24-2010, 05:39 PM
  4. 98 grand prix se key stuck in ignition
    By Squishy in forum General Tech Discussion
    Last Post: 11-25-2009, 01:45 AM
  5. 2008 grand prix key stuck in ignition
    By goldcoinkid in forum Introductions/Noob Questions
    Last Post: 08-31-2009, 05:11 PM
