Thread: Pressure Control Solenoid replace
Results 1 to 20 of 32
  1. #1 Pressure Control Solenoid replace
    Dec 2011
    MN
    wifes car thru a P1811 code the other day, only does it when its 90 degrees plus outside and the tranny gets up to temp. Brought it to a shop and wasted $100 having them look at it, quoted 3800 for new transmission, i laughed.
    Car has 127,000 miles on it, tranny flushed every 30k. Rest of car is solid, just got done putting all new brake and fuel lines in myself.
    Anywas I was thinking of trying, replace pressure control solenoid (going to order from rock auto, AC delco) and a transgo SK 4t65E shift kit (already have in hand).
    So my question is, does this seem like a reasonable approach? and is there a good tutorial on how to get access to this? I know you have to drop subframe and title engine toward driver but doesn't seem that bad.
    Mind you I have replaced the power steering rack a while back so this won't be that much different, in my mind.
    I am planning on buying the K-tool engine support bar because I am sick of using wood and ratchet straps on other cars too.
  2. #2 Re: Pressure Control Solenoid replace
    http://www.tripleedgeperformance.com...ift-P1811.html
    a shift kit can bandaid this issue for most.
  3. #3 Re: Pressure Control Solenoid replace
    Dec 2011
    MN
    10-4, I will start with this because I have all the parts on hand at home. I guess I will slap this in and let here drive. If she doesn't say anything, good to go for a while. If if pops up again, I will look at tackling the PCS. If that still doesn't fix it, I guess I will look into a basic transmission from triple edge performance and swap time.
    does this sound reasonable?
  4. #4 Re: Pressure Control Solenoid replace
    sure does. a qt of some trans medix type stuff might help too.
  5. #5 Re: Pressure Control Solenoid replace
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    trans go shift kit, and some lucas....probably cure you for a long time.
  6. #6 Re: Pressure Control Solenoid replace
    Banned
    Jan 2013
    Colorado
    i literally just replaced this, pm me if you need help
  7. #7 Re: Pressure Control Solenoid replace
    Dec 2011
    MN
    lol. my brother in law used to be a mechanic and thats exactly what he told me!
    go get a transgo shift kit some lucas and your good to go for a while.
  8. #8 Re: Pressure Control Solenoid replace
    Dec 2011
    MN
    Question, can I reuse the accumulator gasket or should I get a new one? O'rielly's does not carry it.
  9. #9 Re: Pressure Control Solenoid replace
    Mar 2014
    Tucson
    Quote Originally Posted by scha0786 View Post
    Reuse it.
  10. #10 Re: Pressure Control Solenoid replace
    Dec 2011
    MN
    dropped the pan last night and this is how it looked inside. Going to work on the shift kit tonight and buying a new Dorman pan with a drain plug because that sucked tyring to drain the fluid last night. I think it looks pretty good for never being dropped in 127,000 miles.
    Pressure Control Solenoid replace Attached Images
  11. #11 Re: Pressure Control Solenoid replace
    Dec 2011
    MN
    yeah after reading the how to article on here i realized it said to reuse it. thanks
  12. #12 Re: Pressure Control Solenoid replace
    GXP Level Member
    Mar 2015
    Tomball
    That pan looks nice and clean for sure.
  13. #13 Re: Pressure Control Solenoid replace
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    A lot better than mine at 85k. lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  14. #14 Re: Pressure Control Solenoid replace
    Dec 2011
    MN
    Hopefully this shift kit solves my P1811 issue i encountered.
    Otherwise the boss (wife) who drives this is demanding a new car, lol. She says I am spending way too much time in the garage working on the car lately.
  15. #15 Re: Pressure Control Solenoid replace
    GXP Level Member
    Mar 2015
    Tomball
    Sounds like you need to get rid of her and get a new one... you don't need that kind of negativity in your life.
    Jeff
  16. #16 Re: Pressure Control Solenoid replace
    Mar 2014
    Tucson
    Quote Originally Posted by J57ltr View Post
    Jeff
    WAYYYYY cheaper to get a new car.
  17. #17 Re: Pressure Control Solenoid replace
    Quote Originally Posted by BrandonHall10 View Post
    Not always!
  18. #18 Re: Pressure Control Solenoid replace
    Dec 2011
    MN
    just did a search and looks like that it is pretty normal for summer time.
  19. #19 Re: Pressure Control Solenoid replace
    Jul 2010
    Coquitlam,BC,Canada
    I installed my shift kit 5 years ago. P1811 is long gone, but she still wines. I change the fluid at least twice per year. Hoping she stays strong for a few more years at least.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  20. #20 Re: Pressure Control Solenoid replace
    Dec 2011
    MN
    lol
    tell me about it. We went and looked at new cars tuesday night and showed her the payment of $411 for the next five years. She agreed that if I can fix it, lets run it till she goes down.
    Anywas, got the shift kit in last night. Installed a new transmission pan (Dorman with the drain plug), used the felpro gasket (way nicer than the stupid wix one) and throw in 12 ounces of lucas with all new valvoline Dex 3 fluid. Got 30 miles on it so far and is shifting nice with no codes. Today is suppose to be 98F here in minnesota with a dewpoint of 80F so if it is going to slip or act up, it should be today.
    Curious what the tranny temp should be, it likes to hang around 195F with a coolant temp around 205F. This is with the A/C on. Mind you it is hot out.
  1. Replace Pressure Control Solenoid
    By gates1847 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-17-2020, 01:58 PM
  2. pressure control solenoid ?s
    By circa09 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2011, 03:53 PM
  3. Pressure control solenoid?? HELP
    By gtpman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-14-2010, 08:56 AM
  4. Pressure Control Solenoid?
    By Klutch in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-04-2009, 01:09 AM
