Thread: Towing questions
Results 1 to 16 of 16
  1. #1 Towing questions
    GT Level Member April Thompson's Avatar
    Dec 2014
    Moline, IL
    I was wondering if any helper springs or whatnot would be recommended for towing a small pop-up camper with my 04. I have seen other cars purport to tow up to 3500 lbs, and yet their tails are in the weeds with even 1/2 ton of weight on the hitch... and these are bog standard cars! Just want to make sure I don't end up like that!
    2004 Grand Prix GT2-clone A.K.A. the "Cybercar;" Galaxy Silver; 146K miles; RETROFITS: leather-wrapped steering wheel (w/audio controls) & shift knob; trip computer; map lights & dual lighted vanity visors; heated (?) leather seats w/ 10-way power driver's seat; ​HUD conversion
  2. #2 Re: Towing questions
    I think the owners manual says it can tow a max of 1,000lbs.
    No way in hell I'd try to tow anything that heavy or even 3,500 lbs. That just not safe in a car like these and so much stress on the transmission.
  3. #3 Re: Towing questions
    I didn't realize those pop up campers weigh that much.
  4. #4 Re: Towing questions
    theres no way in hell a pop up weighs that much. i used to walk one around by hand, aka lift it up and move it alone.
    my 24 foot boat was 4000 lb's. you just try to lift the tongue of that trailer lol
  5. #5 Re: Towing questions
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    I've seen Buicks pull just fine. The problem is that they don't like to do it for long. Don't think I've ever seen a hitch on a GP.
    A word of cation from personal experience: My car has less miles at 135k. Deviating from "normal" driving has shown me that there is a %100 chance my t465-e is in need of internal parts, and not just from me hammering on it half a dozen times.
  6. #6 Re: Towing questions
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    I would double check the weights of the pop up and check your owners manual. Also keep in mind that the owners manual splits out towing weight and cargo. If you are hauling cargo and such, that reduces how much you can tow. I would certainly not tow in OD, but it could still be hard on your trans.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  7. #7 Re: Towing questions
    Jul 2010
    Coquitlam,BC,Canada
    These cars weren't designed to tow and aren't that popular to tow with.
    Pop-ups will be less than 2000lbs (200lb tongue).
    Yes, you can tow with it.
    Heavier coils would be your only option without something custom made. If you don't have a tranny cooler, get one, or don't tow.
    Personally, I would not tow with my GP.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Towing questions
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Pintle weight and towing load are definitely 2 different things. If a trailer is well balanced, you can lift the tongue with almost no effort.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  9. #9 Re: Towing questions
    should you go through with a hitch install. once you put the trailer on the car you want your hitch low or high enough to make the frame of the trailer level. if its low or high it will sway like a monster behind you, very unsafe and unstable.
  10. #10 Re: Towing questions
    Dec 2014
    Moline, IL
    No, pop-ups don't weigh that much, except for the larger 2-axle units; I just wanted to find out if my car could indeed tow that much, and the answer is it can barely pull its own weight! Disappointing, since the Gen 7s (88-96) could pull up to 3500 lbs all day long!
  11. #11 Re: Towing questions
    Jul 2016
    Grande Prairie, AB
    Get a weight distribution hitch, if you can... It makes a world of difference for towing.
  12. #12 Re: Towing questions
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by drperry View Post
    You need weight for W/D systems. Tent trailers don't weigh enough for W/D to be effective.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: Towing questions
    Jul 2016
    Grande Prairie, AB
    Quote Originally Posted by Bronco Boy View Post
    If there's enough tongue weight to sack the suspension, then W/D hitch will work... Pricey, but it'll do its job. Also helps with sway control, if it's set properly.
  14. #14 Re: Towing questions
    Jul 2010
    Coquitlam,BC,Canada
    Exactly. In this case, we have minimal tongue weight (150-200lb max).
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  15. #15 Re: Towing questions
    Jul 2016
    Grande Prairie, AB
    True enough... Brain cramp on that one, lol. I'm not used to seeing little trailers anymore... Even the tent trailers are all tandems up here, lol.
  16. #16 Re: Towing questions
    GTP Level Member
    Aug 2012
    st louis park, MN
    I used to tow motorcycles with my 2008 grand prix somewhat regularly. If we assume each moto is 430lbs, the open trailer at 400, and another 500 in gear we are talking over 1500 lbs. I towed thousands of miles this way although most of it was highway miles and I now have 132k miles without any known issues. Some of the towing I did without a transmission cooler nor shift kit and some of it was with both.
    From the discussions I've had, some generations of the transmission do NOT have a hardened 4th gear hub and are more likely to fail (so tow in 3rd). I'd recommend checking that you have fresh fluid, a transmission cooler which helps the temps significantly, a shift kit, and driving without cruise control if you are in hilly areas or you find the trans shifting a lot (you can better keep the trans from shifting with your foot).
    As others have said, watch your total weight, the tongue weight/balance of the trailer, and just take it easy. If you trans has any issues I'd stay away from towing.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  1. towing??
    By Drifty in forum General Grand Prix Discussion
    Last Post: 02-03-2014, 01:32 PM
  2. Towing with a GP GT?
    By Brammer in forum General Tech Discussion
    Last Post: 09-19-2013, 09:20 PM
  3. Towing a GP
    By anemesnyik in forum Introductions/Noob Questions
    Last Post: 08-21-2013, 12:55 AM
  4. towing the gp
    By stlunatics2oo3 in forum Off Topic Discussion
    Last Post: 01-10-2011, 10:33 PM
  5. Towing with a GTP
    By bryguy322 in forum General Tech Discussion
    Last Post: 05-02-2009, 10:02 PM
