Thread: Switched to e85
Results 1 to 4 of 4
  1. #1 Switched to e85
    May 2016
    michigan
    So I finaly did the switch. Dropped in the 60's, tuned, 3.4 pulley, headers, 1.9s and 104s. So question on long and short term fuel trim. What should I be seeing there? Car is running great as far as I can tell. Pulls grea. 0kr @ 9.5psi
  2. #2 Re: Switched to e85
    Kemmerer, Wyoming
    Within 5 either plus or minus 0
  3. #3 Re: Switched to e85
    May 2016
    michigan
    Ltft is at about -8 cruise stft is within 5 ask the time. Both 0 out at wot. Sound right?
  4. #4 Re: Switched to e85
    your trims are still learning. once the wot ltft stops gong to zero and you see a neg or pos number then they have learned.
    stft mean nothing really for looking at. they should zero out when wot, and bounce around the rest of the time.
  1. Switched 12V source?
    By Sudden in forum General Tech Discussion
    Last Post: 09-13-2015, 11:29 AM
  2. 12v switched from side fuse box
    By dgjks6 in forum Audio, Security & Visual Electronics
    Last Post: 01-09-2015, 10:52 PM
  3. Just switched to E85... Here's what I learned!
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 07-11-2014, 09:07 PM
  4. switched accessory tap
    By ham4864 in forum Audio, Security & Visual Electronics
    Last Post: 12-10-2010, 11:21 PM
  5. 12volt switched source?
    By nyydmb12 in forum Audio, Security & Visual Electronics
    Last Post: 10-19-2009, 06:45 AM
